My thought on the matter is that the MPPT controllers are just that. A Maximum Power Point Tracker. A typical Solar Panel does not produce any usable wattage when the panel is disconnected.
This means that when you do not have a load on the Solar panel then there is no power being generated. When you put a load on the panel. the voltage on the panel is reduced and then it starts to produce power. The MPPT Controller looks for the ideal voltage to produce the most power.
If you are producing more power than the MPPT controller is capable of then it just uses a different voltage that produces less power and the panels become less efficient.
It is just the way the Solar Panels are built. In order to produce the maximum amount of power then then need to operated at the ideal voltage which produces the most current. Ohms law states that Voltage time Current is equal to wattage.
For a wind turbine, all of the power the turbine generates must be used so they have a load resistor that engages to use the power. On the grid all of the power must be used. If the power on the grid or the wind turbine is not used then bad things happen.
Solar panels are totally different. You can put a solar panel out in the sun and not connect the leads and nothing bad will happen. Basically, a MPPT controller just raises the voltage of the panels up to the point where they produce less current. If you have a Victron MPPT 250/100 amp like I do, then it will only produce 100 amps of current and will let the rest be wasted.
