Visionquest
I won't be heating the cells past 45-50 degrees F. The wattage of the heat pads will be around 20 watts total spread across the sides and bottom. I don't want to create hot spots which is why my original questions focus on use of an aluminum plate in contact with the heat pads. I think its clear now that I don't want to put the aluminum plate directly against the cells due to potential for shorting cases together. Placing the heat mats directly on the cells could create a hotter area where they directly touch. May not be an issue but will need some testing. The final thought I'm having is to put heat mats on an aluminum plate but electrically isolate the plate from the cells using a thermally conductive dielectric material. This would apply the heat evenly to a large surface of the cells but remain safe from shorting cell cases.
Anyone doing this?
Anyone doing this?
