ScrotpusGobbleBottom
Corn Pop was a bad dude.
No clue. That is between you and the BMS. from the screen shots I do not see any obvious way. Perhaps that pencil edit button does more than change the name of the battery?How do I change it?
My world 100% was fully completely as in the tragically hip.
Cell over voltage in your BMS is set to 3.75. This is a bad practice. I would change that to 3.66
Cell under voltage i would set at 2.8
Oh geez I can’t figure out how to change that setting![]()
Will it work if I just watch it manually and then turn off the charger will things be able to balance out or is that even a thing?
Here is soc atm
You got a bit to go for sure.I’m at 3402 right now
Yeah, the bms is lying to you and not calibrated. As others have mentioned, it should be a lot more accurate for a while after you finally charge it to 100% actual.Here is soc atm
all good.Now I drop back again 13 62 V
Did current go to zero?It will not take anymore
It’s bouncing between 13 62 and 13 63
Does anybody have any suggestions as to what I should do next?
