hwy17
Anti-Solar Enthusiast
I think we could still use detailed wiring pics. There's all sorts of possibilities and people jump to conclusions especially about grounding and bonding.
Auto transformer looks hard wired into 120v loads panel (right panel). Flipping its breaker (left panel) would remove both L1 and L2 so no chance of 120V loads being unbalanced.More info: If your autoformer were to fail or pop it's breaker, you would apply 240v to all your 120v appliances... is it worth it? A wife flipping the wrong breaker for example could cause the microwave and fridge to get fried.... is it worth it?
Just a quick follow-up to my advice I offered. I fed my family working as an electrician giving me enough knowledge to know I can't walk you through this online and be 100% certain of your family's safety.Thank you for the concern, much appreciated. I disconnected completely the outlet and wire that ran to the metal box screwed to the shipping container to limit the circuit to just the inverters, circuit breaker panels and transformer. This would allow me to trouble shoot within that specific space. Ive been reading up and the issue seems like its a ground/neutral bond from the inverters. Apparently there is a US version and a European version.
DIY is the name of the forum. Everyone here is tacitly accepting the risk of their own actions and understanding the nature of the advice received.To those posting help do you feed your family doing electrical work? or is this a hobby? The OP has a right to know just how much you really know.
These are not setup for North America .purchased from Alibaba
And I'm pretty sure he's got no NG bond at the breaker panel. Having NG bonding screw in Growatt and NG bond at the panel would cause a short circuit through the autotransformer and trip the inverter.You don't have a N/G bond.
And I'm pretty sure he's got no NG bond at the breaker panel. Having NG bonding screw in Growatt and NG bond at the panel would case a short circuit through the autotransformer and trip the inverter.
Not in the least just look at the wide variety of answers thrown out there from the armchair DIYers. Every response should have first asked and received more information before making their wild a** guess based on what they think they know. It's called the Dunning-Kruger Effect.First, this is DIY.
Second, it is pretty arrogant of you to assume nobody here knows anything about this sort of problem.
Many here have practical experience and more than enough education to know what they are saying. I know I wouldn't give advice in here until the OP posts back pictures and a wiring diagram so I wouldn't give a wrong answer.
I can see your point that the OP should carefully consider the advice he is given before doing things. And be double careful about testing before letting his famliy near. But it doesn't take a certified master electrician to track down an issue like this.
Helpful people offering possible solutions based off the information someone provides isn't Dunning-Kruger lol.It's called the Dunning-Kruger Effect.
ExactlyAnd I'm pretty sure he's got no NG bond at the breaker panel. Having NG bonding screw in Growatt and NG bond at the panel would case a short circuit through the autotransformer and trip the inverter.
I don't need any pictures to know what the problem is.Not in the least just look at the wide variety of answers thrown out there from the armchair DIYers. Every response should have first asked and received more information before making their wild a** guess based on what they think they know. It's called the Dunning-Kruger Effect.
End of rant
Detailed pictures of each panel and device wiring would help.
Please…
Before you attempt ANY troubleshooting, get good lighting, and take detailed pictures of everything connected to the container, let us see the boxes, wires junctions everything.
We may see the issue right away, and save you a lot of headache.
