Coming from 2 EcoFlows I decided to try out the EG4 3000 and Lifepower 4. After install I adjusted battery type to EG4. System charged up battery to 100% and alarmed, disconnected. Read forums and connected BMS_test. firmware current at 3.37 and error reports as "Charging MOS fault alarm". More forum reads but no idea how to fix. I tried reseting the battery both while connected and disconnected from inverter and the run light illuminates momentarily and immediately an alarm code.
Cell_6 is showing red at 3.397v and max_diff is 0.052.
That's all I got. Any suggestions for this newbie?
Thanks
-Steve
Thanks
-Steve
