Drunkin Solar
That might be silly for you, not for all. Get some air kiddo
Why you getting personalIf that is the case then this isn't the place for you. You should working with one of the below firms.
ThankyouJust for informational purposes, Solis has single unit string inverters that go up to 350Kw a unit, very compact and have all the features for remote monitoring and control. You want to have a distributed architecture not a single point of failure and these large units are used in solar farms in the USA.
https://www.solisinverters.com/global/inverter.html and https://www.solisinverters.com/global/solarinverter25/S6-GU350K-EHV_gl.html
It really depends on your layout; in the US string inverters are often used with single axis trackers for one row. Central inverters are going to have a lot of DC combiners and cabling at 1.5kV which can get unwieldy for maintenance.Hi, No going for 3.3MW central inverter. And yes central inverters are better and convenient
ThankyouIt really depends on your layout; in the US string inverters are often used with single axis trackers for one row. Central inverters are going to have a lot of DC combiners and cabling at 1.5kV which can get unwieldy for maintenance.
For very large projects (>200MW) the central inverters are more easily justified.
Look at the name of this forum.Why you getting personal
No, but they have a lot of help desk call centers…Do they have Google in India?
But he would have to call a USA number to get a help center in India.No, but they have a lot of help desk call centers…
He could probably try one of those.
Well, given that the previous request for exactly the same thing, with an undefined description of what was meant, was a school project, and given the that the OP seems to also have no idea about solar power systems, much less grid-scale, it felt like another class assignment. Either way, not the appropriate forum, though learning about the basics is the same.Seems like the difference between "string" and "central"
