Renogy Scum!!!!!
Urge38
London Uk
Rant but be warned when buying from Renogy
So, I purchased a New LifePo4 50ah battery from Renogy uk (no such thing) through eBay Uk (I live in the Uk)
I charge the battery at home, indoors (warm) via a mains 10a charger (LifePo4) and use the battery for only one cycle per day, maybe four times a week,
I had the battery four months when I noticed a lack of capacity.
So, I did a capacity test, wait for it !!!!! drum roll!!!!! 55% capacity!!!! can't be!!! so ive done the test a few times since,
yep, a 50amp battery is only giving me 27amps after four months.
ok, I thought best I try a new charger, so I bought a Victron charger, still the same, only 27amps from a 50-ah battery
Do you think Renogy wanted to know!!!???
all they want and have done is give me the run around,
please sir, be kind enough to run this test, O and now you have run that test, please sir can you run test again, O please sir, second team is looking into you complaint
Ebay are not interested, my credit card compony are not interested because I purchased it through a platform
SO BUYER BE WARE
Renogy are Scum, and if I had not used eBay, but purchased directly from Renogy, I would have been covered by my credit card company.
Don't make this mistake people
Unfortunately, Renogy customer service is poor at the best of times. I watched a video where the 100Ah Pro version failed to stop discharge at 10V and went into low voltage protection and wouldn't wake up. They sent the guy another battery and almost same thing, except this replacement took a charge again. Renogy said it was due to it being discharged at 0.2C during his capacity test 😆 I almost bought one till I saw that video. Close call
You just got to laugh or else you cry
mine is steady to around 11.50V then it nose dives to 10v in minuets
That makes sense. 2.875V / cell is all but empty.
Is the battery sealed? Can you see individual cell voltages from the BMS or measure them with a meter? What voltage are you charging to?
I'd bet your cells are way out of balance causing the majority of your issues.
Its too bad Renogy cant figure out customer service.
They seem to have a captive audience and manage to sell products at a higher price than others. Then its disappointment from there...
Theyd have one heck of a business if they took half of their advertising budget and put it into product quality control and some educated tech reps to answer the phone.
They are known to use BMS that doesn’t balance and slowly becomes unbalanced at the sacrifice of capacity.
I still say a proper test of these economy off the shelf batteries is if the BMS can balance cells. Everyone loves to do tear downs and low temp protection. Balancing is way more important.
I watched a you tube video of my exact same battery, some guy had two taken to him to revive, he opened them up and hey presto, unbalanced cells
Is it possible to open it up and either change the bms to a cell balancing bms or simply charge the cells individually
my Renogy 3000w inverter has performed flawlessly in the 12 months that i have had it ....
Renogy is basically Chins with Lipstick, my very frist batteries were renogy 170ah and they would test to about 115, this is well documented as many other170 ah renogy are acting the same way. So most probably grade B cells.
There are better brands now: Epoch, SFK, SOK, Aolithium, Voltgo, Volithium so yes avoid Renogy.
I do like there inverters & solar chargers though.
that's what I would expect, 12V would be 9ish % capacity and the bottom knee is below that, batteries I wouldn't buy from renogy myself, but I do use their hardware as a normal working guy can't afford Victron. :LOL:
This thread is about Renogy batteries. All Renogy products work fine until they don't. They're notoriously bad at support and communication.
The thread was about Renogy being scum ....otherwise it would have been titled Renogy Batteries are Shit .... and you will find that ALL products, irrespective of manufacturer work until they don't......
Can't comment on Renogys support and communication other than what I've read, which does seem to support your experience that it is rather shit ....
SO BUYER BE WARE
It it this one?
SO BUYER BE WARE
Ya mean the same company that sold me my first new panels 3-4 years ago and when I hooked them up “1/2 “ the mc4 connectors on them crumbled or broke in half in my hands like a potato chip..?
Is that the same company yer talking about..?
Well I understand … cause I trust them about as much as I trust their connectors…
I never even considered wasting my time on a warranty call …..my time hangin on the phone with some clerk trying to tell me I did somthing wrong is worth more than 32 cheap connectors…I just fixed it and moved on…
it’s the way of life nowdays…
Damn cheap stuff is takin over the world……
J.
mine was a different model, but it seems it doesn't matter what model, they are all toilet
Would you consider opening it up, even if you had to physically cut it, and balancing the cells? At some point after days of dealing with something, no longer worth my time, they win.
FWIW, I bought some individual 50 ah cells and case and busbars and BMS to build my own, and there was very little cost difference for what I see in the US for the Renogy 50 ah battery and the from China cells, case, BMS, etc. I do know the quality I'm getting from a reputable Chinese dealer.
What’s up with people here having mc4 connectors “crumbling”? (Second thread in a few days mentioning that) I have Renogy panels that are over 15 years old and some that are a year old, and never had a connector break in half, let alone “crumble”. I can’t speak for their batteries, but I have had zero issues with their panels or charge controllers. <shrug>
