Looking good!Found a quick 2 hours to get them and the panel on the wall. That's all for now, gotta go to the HD and FFL dealer after some lunch. View attachment 217353
( the panel is intentionally not centered)
That looks like it, you have to request a quote for accurate pricing. Iirc it was listed for the same price in your link but I was quoted $875.Is this the unit you got from the store you got it? their price is already up?
Factory Pv Inverter 110vac 48v With Parallel Function 10kw Single Phase Hybrid Solar Inverter - Buy Solar Inverter hybrid Solar Inverter parallel Solar Inverter Product on Alibaba.com
Factory Pv Inverter 110vac 48v With Parallel Function 10kw Single Phase Hybrid Solar Inverter - Buy Solar Inverter hybrid Solar Inverter parallel Solar Inverter Product on Alibaba.comwww.alibaba.com
Mine have been hung up in Hong Kong for several days. Shipping is thru UPS.Ordered from "SRNE Power Store" on AliExpress.
https://www.aliexpress.com/item/1005006779462705.html
Was ordered and paid for on April 19, after some back and forth with the company it was finally shipped April 30 and came in today, May 10.
Took longer then expected due to fedex issue in Hong Kong.
Tracking info:
10 May 202409:58
Delivered
FEDEX- 10 May 202406:45
On FedEx vehicle for deliveryMB, Canada
FEDEX- 10 May 202406:34
At local FedEx facilityMB, Canada
FEDEX- 10 May 202403:54
FEDEX- 09 May 202414:31
FEDEX- 09 May 202413:31
Shipment exception MB, Canada
FEDEX- 09 May 202413:30
International shipment release - Import MB, Canada
FEDEX- 09 May 202411:32
On the way MB, Canada
FEDEX- 09 May 202409:09
At destination sort facility MB, Canada
FEDEX- 09 May 202406:40
Departed FedEx hubMEMPHIS, TN, 38118, United States
FEDEX- 09 May 202404:53
On the wayMEMPHIS, TN, 38118, United States
FEDEX- 08 May 202400:35
Arrived at FedEx hubMEMPHIS, TN, 38118, United States
FEDEX- 07 May 202415:17
Departed FedEx hubANCHORAGE, AK, 99502, United States
FEDEX- 06 May 202415:50
At local FedEx facilityANCHORAGE, AK, 99502, United States
FEDEX- 06 May 202415:49
On the wayANCHORAGE, AK, 99502, United States
FEDEX- 06 May 202413:18
Arrived at FedEx hubANCHORAGE, AK, 99502, United States
FEDEX- 06 May 202420:41
On the wayTA YUAN DISTRICT, 337, Taiwan
FEDEX- 06 May 202420:40
FEDEX- 06 May 202420:29
Scheduled delivery updatedTA YUAN DISTRICT, 337, Taiwan
FEDEX- 05 May 202421:01
At local FedEx facilityLANTAU ISLAND, 99999, Hong Kong
FEDEX- 04 May 202421:37
FEDEX- 03 May 202423:26
FEDEX- 02 May 202422:27
FEDEX- 01 May 202420:53
FEDEX- 30 Apr 202423:35
FEDEX- 30 Apr 202413:29
At FedEx origin facilityTSUEN WAN, 230, Hong Kong
FEDEX- 30 Apr 202412:52
Picked upTSUEN WAN, 230, Hong Kong
Ever heard the saying, "snooze, you lose."Is this the unit you got from the store you got it? their price is already up?
Does the install manual specify mounting on a non combustible material and does the 2x4 qualify as that?Found a quick 2 hours to get them and the panel on the wall.
I don't know, I didn't read that part of it.Does the install manual specify mounting on a non combustible material and does the 2x4 qualify as that?
Wood makes an easy mounting material, but I thought I couldn't use it.
Mike C.
I use Unistrut always.I don't know, I didn't read that part of it.
I used strut for the ASF but I'm trying to save the rest for my next array, saw an old 2x4 in the corner and thought perfect.
I have tapcons through the 2x into the cement so even if it burns the SRNE's won't fall.
Manual mentions the following for installation:
3.1 Installation location
ASP series is only for indoor use (protection level: IP20). Before selecting the installationlocation, users should consider the following factors:
A solid wall
Installation height: flush with the line of sight
Sufficient heat dissipation space
Ambient temperature: -10°C−55°C (14°F−131°F), to ensure optimal operation
*dimention drawing of required free space around inverter*
DANGER
Do not install the inverter near highly flammable materials
Do not install the inverter in potentially explosive areas
Do not install the inverter and lead-acid battery in enclosed spaces
CAUTION
Do not install the inverter in direct sunlight
Do not install or use the inverter in damp environments
So, mounting it on 2x4s or a plywood backing is acceptable... just don't store oily rags, gasoline nor hay bailes close to it and you should be ok....lol.
I swear price was $1099 when you first put up this link. Now $1299.Is this the unit you got from the store you got it? their price is already up?
Do you have a Menards near you? Their wire prices are better, I believe, plus you can get 11% back which helps. Copper is near $5/lb. I bought several hundred feet of #2 copper thhn years ago for $55. I had a hard time carrying it. Seemed like a lot at the time! Ha ha.Install delayed ... Due to my extreme frugalness I refuse to pay HD wire prices. Placed an order at shopwirenco for ~30% less than HD and ordered a bunch of other stuff I didn't really need but will use eventually.
I'll more than likely order 16 more cells today or tomorrow, haven't decided on Gobel or Docan yet (not waiting for overseas shipping).
Found the data Sheet for thisAfter doing a bit of research I've decided to bite the bullet myself and take a chance on buying an APS unit, with plans to buy a 2nd one later on, from here:
SRNE 10KW Support Split/Single-phase 48V To 110/240VAC Hybrid Solar Inverter Dual MPPT Max 22A Charge Current Pv Max 500VOC
Store: SRNE Power Store
Model: ASP48100U200-H
Price: $2,126.19 Canadian Dollars
Not exactly cheap since I'm paying for it in Canadian Pesos...lol...but still one heck of a deal, based on it's capabilities.
I guess I'll see once it gets to me, currently in transit... I'll keep you all posted
Unfortunately I do not. I wish I were stocking up on copper years ago... I bought bought enough from Wirenco that I should be covered for at leat one more expansion.Do you have a Menards near you? Their wire prices are better, I believe, plus you can get 11% back which helps. Copper is near $5/lb. I bought several hundred feet of #2 copper thhn years ago for $55. I had a hard time carrying it. Seemed like a lot at the time! Ha ha.
Plus I kept a bunch of #8 and larger that was going to be thrown away years ago. Long ago it wasnt worth recycling unless you had hundreds of lbs of it. Most of it went in the trash. The rest was given away.
Can I get your link to the Manual?You are looking at page 23 of the manual. That is incorrect for 240V split phase here in the US.
This is what it states for the diagram you posted:
4.9.4 Wiring diagram for two-phase parallel connection (phase difference
between L1 and L2: 0°)
(1) P1: Set the item [31] to "2P0;" P2: Set the item [31] to "2P1," all of the P1/P2 inverter item
[68] can not be set, it is default “0°”and the phase difference between P1 and P2 is 120°.
When setting the item [38] to "120 V," the voltage between the live wire L1 of P1 phase and
the live wire L2 of P2 phase is 208 V, and the L1-N voltage is 120 V
(2) P1: Set the item [31] to "2P0;" P2: Set the item [31] to "2P2," all of the P1/P2 inverter item
[68] can not be set, it is default “0°”and the phase difference between P1 and P2 is 180°.
the live wire L2 of P2 phase is 240 V, and the L1-N voltage is 120 V, L2-N voltage is 120V
The correct page you need is page 28 which is for split phase 180° between L1 and L2 which is stated:
4.9.5 Wiring diagram for split-phase parallel connection (phase difference
between L1 and L2: 180°)
Set the item [31] to PAL, and set the item [68] to 180°. When setting the item [38] to
"120 V," the L1-L2 voltage is 240 V, and the L1-N voltage is 120 V, L2-N voltage is 120V
a. Two parallel-connected solar storage inverters:
Note how L1 from each inverter is combined and each L2 is combined.
Post in thread 'SRNE 12kW IP65 HES and 10kW ASP' https://diysolarforum.com/threads/srne-12kw-ip65-hes-and-10kw-asp.81544/post-1059043Can I get your link to the Manual?
Thanks
I'd be very wary of posted max limits.... sometimes you get lucky and nothing happens, but more othen then not the hardware will fail just below or close to those listed limits... usually there is a very short time limit of functionality at those limits. Milage will vary dependent on luck and slight differences in hardware and parts used...Its impressive that they consider ambient temps up to 131 acceptable.
Agreed.I'd be very wary of posted max limits.... sometimes you get lucky and nothing happens, but more othen then not the hardware will fail just below or close to those listed limits... usually there is a very short time limit of functionality at those limits. Milage will vary dependent on luck and slight differences in hardware and parts used...
lol it went up again oh boyI swear price was $1099 when you first put up this link. Now $1299.
That would be the HESP.I'm getting confused with all these SRNE units. Wasn't there one that was supposed to come with some CT's for limiting export?
Try emailing them and asking. I've found they are responsive to technical questions using the email on their website.Considering trying a SRNE HESP48120U200-H (Hybrid 12KW) inverter. I have reviewed the manual but not clear to me if this has a built in transfer switch and can be installed between the meter and the main service panel (like a SolArk) or only a secondary critical load panel. It does support zero export (CT's required) but can't tell if it disconnects from grid during outages or simply prevents backflow.
Anyone know???
Perhaps it could prevent backflow (current flow) via CT's alone, but without a disconnect not sure how it would prevent the lines from remaining energized (voltage present). I would like to do whole home backup but unclear if I need to get an automatic transfer switch or not.Wouldn't it have to disconnects from the grid during outages to prevent backflow
