Voltronic RS232 Inverter USB Cable for Solar Assistant
FrankieG3011
Caribbean
Good Day,
I am considering purchasing the Rasberry pi kit for Solar Assistant. However, I notice that they offer a Voltronic RS232 Inverter USB Cable for connecting to the Inverter.
I have the EG4 6500EX that I am currently using, and this is listed as an Inverter under the Voltronic category. I have a cable that came with the EG4 6500EX. Is this the correct cable that can be used with the kit and Solar Assistant? Will it work?
Grateful for your input. Thanks
Good Day,
I believe that is the correct cable, yes. Looks like the new firmware cable that SS started supplying with the 6500s.
Your manual indicates on page 60 the Pin Assignment for BMS Communication Port:
PIN 1 RS232TX
PIN 2 RS232RX
PIN 3 RS485B
PIN 4 NC
PIN 5 RS485A
PIN 6 CANH
PIN 7 CANL
PIN 8 GND
I could not find the pinout for the adjacent port but EG4 normally wires then the same
In the picture you provided it appears pins 1 & 2 (the two left most pins) are the ones is use which it appears would make it an RS232 to USB cable.
Solar Assistant can also use an RS485 to USB cable which is what I use to connect Solar Assistant to the batteries. Solar Assistant can communicate with the inverter and each battery in your battery stack using two separate cables. Not sure what batteries you have but for EG4 Lifepower4 batteries the RS485 cable must use pins 1&2 to connect your battery stack to Solar Assistant.
PIN 1 RS232TX
PIN 2 RS232RX
PIN 3 RS485B
PIN 4 NC
PIN 5 RS485A
PIN 6 CANH
PIN 7 CANL
PIN 8 GND
I could not find the pinout for the adjacent port but EG4 normally wires tyhen the same
The cable is different for inverter communication or battery communication. The same one will not work for both. This bit me in the beginning because I kept trying to use the battery cable to connect the inverter to SA and it wouldn’t work.
I’m sorry folks. After many posts read, 5 USB cables, 2 cables matching the one in the original post, SA shows nothing, and doesn’t see the inverter. I started SA with the 6500-ex and 1 battery in January and it worked fine. Mine is just set up to be power outage back up for now, no solar. I shut it down for 2-3 months, then added 2 more batteries, and since SA doesn’t work at all. I’m just lost.
I’m using a raspberry pi 3b, it connects to WiFi fine, can someone just describe the set up in a straightforward manner?
Can you share a closeup of your inverter connections under the display? Don't know of any reason why all the sudden it would stop working.
Sure. Thanks for replying so quickly. This USB cable is the first I used in January that worked.
The ones from Watt247 work. Some micro usb cables can cause one inverter to “hang” and not shut down after pushing the off button. Power back feeding from the pi keeping the logic board on?
