no doubt hence raising the RPM's by hitting the gas. thats on my normal vehicles. my personal truck has a 230 amp leese neville alternator in lieu of its stock 110 amp unit and as such it can put out 150+ at idle. simply bringing it up to 1000 RPM engine speed allows the full 230 amps. So far as the vehicle being jumped. it will only pull what it could pull from a fully charged battery so like any other starter if you crank it too long it will overheat and either burnt he brushes or the windings.
This is the 4000 series I first used as a battery charger in 1988.
Problem regulator failure.
A dead set of batteries would draw over 80 amps from the MG set.
The set used a 13 cubic inch briggs and stratton engine directly coupled to the alternator.
At higher levels of discharge the small 13 cubic inch engine could not develop enough torque to get up to speed.
Speed was set at 3600 rpm and according to the manufacturers ratings this was near the best speed for peak power and efficiency
A bit high if I recall...
Regulators died!!!!!!
What I learned was it was better to removed the regulator and put in series a rheostat from a automotive dashboard to lower the field current at full field so the alternator would not fry the regulator, the engine would not be overpowered by the alternator and the C rate for charging could be kept bellow 80 amps
This rig might still exist.
Ill look for what ever my stupid uncle did with it, might be under a tarp someplace...
Ah...
This is the great leap forward.
The only automatic choke kit that actually works for the small block Honda-clone.
I'm not that smart what I did was adapt the first generation Kohler clone autochoke to the horizontal shaft GX series engines.
Its still the only one ever built as far as I know and it works perfectly for a remote start on command from a charge controller or remote station inside.
