Have not seen a solar generator at Costco, but mine has folks hawking installing PV panels on your house in the isles.Does Costco sell solar generators? Seems like good way to get many introduced to solar..
I hope they don't think they are gonna run those generators off them lil propane tanks for more than 15 mins…Was at Costco. Everyone has a tri-fuel genny. It was a frenzy. $700. Would be brilliant on natural gas. People buying 3 at a time. 200 sold out.
If inverter generator may get a few hours.I hope they don't think they are gonna run those generators off them lil propane tanks for more than 15 mins…
I get about 6 hours on a similar setup. Medium/low load construction.I hope they don't think they are gonna run those generators off them lil propane tanks for more than 15 mins…
A sad thing with people knee jerk buying a generator is the handful of deaths that will result cause of mproper use and lack of knowledge. Granted mandatory CO monitoring and shutdowns does help but you know someone’s going to run it in their garage or make a suicide cord into their drier outlet and the statistics will rise.
Granted those heat index numbers have their own numbers.
Looks like it was in a shed, perfect to build up those vapors and maybe spill a bunch of gas over the running hot engine.![]()
Baytown resident suffers serious injuries after generator being refueled catches fire, spreads to home
The Baytown Fire Department said it happened in the 10000 block of Sweet Gun Lane.www.click2houston.com
Maybe a screen porch?Looks like it was in a shed, perfect to build up those vapors and maybe spill a bunch of gas over the running hot engine.
Their powerhouse sheds are prob bigger than our entire homesMaybe a screen porch?
I’d like to think Texans have more robust built sheds.
I’m sure sunrun pays them to be in the store to bother their customers.My Costco and others I have been to have Sunrun people hawking solar.
View attachment 227858Way to close to the house!
They are commonly disconnected. The Harbor Freight ones frequently flake out. Disconnecting is pretty much standard practice if you need your generator to run reliably. My son in law runs a food truck with a 13,000 watt Duromax. Its been fine.By all accounts the units with carbon monoxide detectors are extremely sensitive, I.e they will trigger outdoors if the wind blows exhaust the wrong way.
I assume you meant to write sight...I bet all the CenterPoint executives have backup systems at their homes.
A few years ago, an electrician was telling me about installing a whole house generator for a local electric company exec. He was laughing because the exec wanted to make sure that it was completely out of site.
I successfully ran mine for several hours in WINTER 10F temps...I hope they don't think they are gonna run those generators off them lil propane tanks for more than 15 mins…
Surely Costco could go to their suppliers and tell them "get me a system like a Bluetti XXX for under $XXX" and have it happen. They have a lot of clout.Have not seen a solar generator at Costco, but mine has folks hawking installing PV panels on your house in the isles.
I don't think they want to deal with hazmat returns.Surely Costco could go to their suppliers and tell them "get me a system like a Bluetti XXX for under $XXX" and have it happen. They have a lot of clout.
