79Westy
Hi Folks,
First time posting. I've had some problems with my Victron system on a recent trip, which has led to some questions/confusion. Maybe you can help clear it up for me.
System Components- 2 @ 206 ah SOK's. Victron Multiplus 3000, Victron MPPT, Victron Orion, Cerbo GX. DIY install in 2015 Winnebago View.
On recent trip, I became aware that one of my SOK's was completely shut down, which left my battery bank (I think) with only a 50 amp discharge capacity. This created some understandable limitations, but wasn't my main concern.
WHEN CONNECTED TO SHORE POWER, or when running my onboard generator- when I would call for Air Conditioning, my victron system would shut down. The color monitor from the Cerbo would just look like a TV that someone pulled the plug from the wall. It would quickly and continually flicker thereafter until i discontinued my call for air conditioning. What I believe was happening was that the call for power to the A/C was being taken on by the lone battery which being shut down by it's bms. Sensing charge from the solar it would quickly try to reboot, and fail again. Hence the flicker. I reviewed my Victron settings over and over again trying to figure out what I had wrong. Everything looked correct. What could I have overlooked?
Here's what I'm confused about. Some people have told me this is the way it should work and that I need to get my batteries working correctly. I don't get it. The batteries should be irrelevant, right? The shore power should fully pass through the inverter and power up to 30Amp that the service is designed for right? I should be able to hook this thing up to a lawn tractor battery if I wanted, right? What am I missing?
Thanks in advance.
Keith in PA
Thanks in advance.
Keith in PA
