So awesome that works... was that information posted somewhere?Excellent!
Thanks apctjb. I also received same advice from Ian at Watts247:
“Press the ENTER AND DOWN buttons simultaneously for 1 to 2 sec. You will need to do this each time you power cycle the unit, which may be never.”
I’m living a beep free life now.
I completed my wiring today and got mine up and running less the solar array. I am setting up my panels in the driveway every day till I get the mount built. I installed a Thornwave smart shunt with data logging to keep an eye on the Growatt. I will take a look at it every day for a while, but so far my idle is 4W to 5W. I have a side by side fridge freezer, wash machine, two battery tenders for lawn tractor batteries, and lighting connected so far. when the appliances are Idle, and all of the lights are off, the Growatt goes back to 4W to 5W draw. The loads were also individually tested with kill-a-watt meters and bounced of the Growatt. My heavier loads were about 10% higher than the kill-a-watt measurements. I account that to line voltage loss, inverter inefficiency and the Growatt system load (fans, WiFi, controllers, display).
Only way I could test mine out at the moment would be to buy temporary lead acid batteries or emulate a battery with my 300 watt bench power supply. I'm tempted to do the latter. I've got at least 2 months until my LFPs get here. If the panels were already here I would buy a cheap pair of lead acid to test with.Power saving mode is off. When power saving is activated, my inverter goes to sleep, but will not wake when I apply a load. So I just leave it off. That is the one glitch I found so far.
I love the shunt. They are hard to get anymore Always sold out. Break it out and see what your draw is exactly.
I just ordered a Growatt 48v SPF-3000TL LVM-ES yesterday. I'm in the same position, waiting for my other 8 Lishen cells to arrive to complete my 48v battery pack. Ian at watts247 suggested I could use a 48v power supply to test the unit. I just ordered a 48v power supply from Amazon and when my Growatt comes I'll test it with the power supply.Only way I could test mine out at the moment would be to buy temporary lead acid batteries or emulate a battery with my 300 watt bench power supply. I'm tempted to do the latter. I've got at least 2 months until my LFPs get here. If the panels were already here I would buy a cheap pair of lead acid to test with.
Thornwave page reads 7 in stock right now. I emailed diylithium on youtube and offered to send mine to him to review/test. Never heard back from him. If you could upload some screenshots of the app in use that'd be great. Might be better not to hi-jack this thread with that.
I'm curious if the idle draw of the inverter whatever that may be(50 watts?) is always cumulative with any additional AC loads added to the inverter. Well, you'd also have to disconnect or measure when there are no charging sources available.
Hope we are talking about the same product. Nevermind, just looked at your second picture. Same product.Here is a snapshot. I am waiting for my batteries to completely discharge so that I can zero it out and configure it for my system. I have Utility power and solar disconnected to drain them. However, you can see the current and voltage. Even on only battery, fridge/freezer was the only thing running over night and the batteries are still full. It is 6:25AM at the time of the snapshot. I had lights on and my fridge was running. I will keep an eye on it and take a snapshot when it is daylight and nothing is running to show you the draw.
By the way, I went to Thornwave's web site and they are still sold out. Where did you find them? I want to get another one.
Nice Repro...would love to see pictures of your set up including breakers/fuses etc....if you could. Thanks in advance!Thanks, 4th D Solar is new to me.
A quick update on my Growatt installation. The Growatt is installed, I wired a disconnects between the Growatt and breaker box and incoming PV panel array, 6 space breaker box, ran 12/2 ROMEX to 3 household outlets, each on its own breaker. The system is grounded and the 4 batteries are in 2S/2P 24V configuration. Only 3 solar panels have been connected to the system provisionally. I still need to build the ground mount.
What we have connected: full size front loader wash machine, 2 full size refrigerator/freezers, 70 pint/day dehumidifier (the hog), 2 sump pumps, and 2 battery tenders for lawn tractor batteries in winter storage. We had all appliances running, and never did it once go over 1100W. The highest load was a little over 30% at one given time. I must admit, the fans got loud, but it is downstairs in the utility room where we can't hear it.
With the dehumidifier running overnight, the batteries were down to 24.1V this morning. Again, with three 320W panels and full sun today, the batteries completely recharged before the clouds moved in around 4:30PM. The 3 panels produced 5.7kWh today. I can't wait to see all six in action.
I talked to our HVAC company, they are going to install a switch that will allow us to select grid or solar operation for our furnace. We are so happy with the Growatt system, that once we get the panel array installed, we are going to expand to a second unit for parallel operation. That will cover almost all of our needs except for A/C, lighting, entertainment and small kitchen appliances. I am happy that our most important needs are covered during outages. It is also going to lower our electric bill somewhat.
Better to do it than to not do it out of fear of the hassle. Might as well line up all your ducks in a row for the local government. Paint a rainbow on it to make sure everyone is pleased. Can't be forced to take down a mural dedicated to a marginalized group. What would we do without gubmint? We'd probably have people trying to charge iPhones in microwaves while snacking on tide pods.I just wanted to chime in again. Please be sure to check your local zoning and permitting before starting any home solar installation. I thought that if I do off-grid, and keep my solar panel array off of the roof, I could bypass all of those hassles. Turns out, I was soooooooo wrong. This is going to cost me to make sure everything is up to code, which according to my electrician friend is. But I still have to pay for a certified electrician to inspect it. Any code violations may be fined, and alterations to come up to code have to be done and inspected again for another charge. I have to pay for permits ($285) and I have to get a zoning permit for the panels ($10).
Don't take anything for granted, do your homework. I messed up and I am paying for it now. Also, if you have neighbors that like to report things to the local authorities (like code enforcement), you could have trouble waiting in the shadows. One of mine kept asking if I had a zoning permit for the panels. I took the initiative to keep the peace, and it led to this.
Be safe and smart.
Where, what city?I just wanted to chime in again. Please be sure to check your local zoning and permitting before starting any home solar installation. I thought that if I do off-grid, and keep my solar panel array off of the roof, I could bypass all of those hassles. Turns out, I was soooooooo wrong. This is going to cost me to make sure everything is up to code, which according to my electrician friend is. But I still have to pay for a certified electrician to inspect it. Any code violations may be fined, and alterations to come up to code have to be done and inspected again for another charge. I have to pay for permits ($285) and I have to get a zoning permit for the panels ($10).
Be safe and smart.
People building backyard dog houses be warned!framed/hardened structure on my property
