Hi All
I recently installed a Daly Smart BMS on my DIY 16s2p LifePO4 battery. I'm communicating via the Bluetooth dongle, and all that seems to be working fine. I don't use a light board.
The one wierd issue is the current and SOC display in the app. The SOC will only increase to 49% regardless. If I set it to 100% when the battery is charged, it will go down with discharge as expected, but on charging will get stuck at 49%
There are also large current fluctuations shown in the app, which are not present. My Victron system and separate Victron BMS both show pretty stable levels while the Daly will be showing +-30A fluctuations.
Anyone have any experience like this? Or able to suggest a remedy![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Cheers
Ian,
South Africa
Cheers
Ian,
South Africa
