shorawitz
I assume you have the 4.2V cells since you're doing 14S. It's usually best to parallel first, then series when you build your battery - make one big battery then all you need is a 14S BMS. You'll want to make sure they are all equalized. What I did with mine was to parallel all 64 cells and charged them to 3.5-ish (I have LiFePO4 chemistry) using my bench power supply (you can buy one on Amazon for not a lot of $$, just make sure you get one that can do 10A or it will take 2-3x longer to get them topped off.) Then I let them rest until the voltage settled and to make sure they balanced each other. Then I built my battery as a 4P16S (LiFePO4.) I also made my own bus bars from copper bar stock. I've attached a Sketchup drawing of how mine are setup. I used 2x8 blocking at the ends and 4 rods of all-thread to compress them. I bought some clear tubing to encase the all-thread rod into for safety. The hardest-longest part was building the bus bars. I wanted as few connections as possible to minimize voltage drop across the whole battery.
Like I said about the Schneider BattMon - I derated the Ah total for mine from 1088Ah rated down to 980Ah and (so far) I haven't seen them drop below 70% as tallied by the BattMon/Shunt. I expect these to last me at least a decade. I have my CC set to 56V Bulk, 54.6 Absorb for 45 mins (though I'm thinking of extending this - I've been extending it as I go and watching the Balancer. The cells never really get past 15mV out of balance. I have Float set to 54V. You can adjust accordingly for your chemistry.
