400bird
Solar Wizard
I agree with stuff being not documented. Also, I've seen plenty of stuff where different documentation goes more in depth into different things. Or where specific documents I didn't have detailed something.Doesn't look like there is much integration in Schneider stuff yet. The docs say the MPPT is not integrated yet and also tells you that you might have to set a charge block in the inverter during daylight hours so that the inverter and MPPT don't charge at the same time. I wouldn't be surprised if there was other stuff not available or not documented.
But, were did you see that the MPPT wasn't integrated? That's interesting.
I don't remember which I chose, but I was able to correct the capacity.The other thing is the Gateway makes you select a fixed number of specific Pylontech battery models and appears to calculate the total battery capacity and other settings from those selections. I'm not sure you can override those settings.
Let me know if you can get it to work. That's how I ended up with these 2 random "SunPower" batteries on my devices screen. I could reset the gateway to remove them, but it doesn't bother me.I need to dig deeper. I use DIY cells with 1120ah and there doesn't appear to be a Pylontech battery setup scenario that would be exactly the same amp hours. I can configure something close which may be good enough. There is also an "undefined" battery selection which I didn't try to see if it was usable. Maybe via generic CAN or maybe it's does nothing at all. No documentation on it.
![1647470137390.png 1647470137390.png](https://diysolarforum.com/data/attachments/87/87607-d2ae6015a8d09bcbf23980b77897d767.jpg)
