krby
Wow! If it is getting hot when the switch is in the "ALL" position then there is a fair amount of resistance across the '2' circuit in the switch. What voltage are you seeing across the resistor?
Ok, no that's not what I meant. I meant: "when apply 24V to the 20Ohm resistor from a variable power supply, it gets hot pretty quickly", I haven't built my system yet (still trying to find some wheeled and/or stackable containers to put it all in) but then I wasn't thinking thru the reality of the parallel circuit dropping overall resistance. Nevermind. I should think more before posting.
