Converting large RV to Solar and Lithium, assistance needed
ironladd
I have a large Fleetwood Diesel pusher with an Onan 6Kw diesel generator, a Magnum MS-2000 Inverter, and four 6V 208Ah lead acid batteries. I don't want to deal with battery maintenance and want to ensure my batteries always have good charge on them.
My plan is to replace the four 6v batteries with two 12v 150Ah / 1920Wh batteries (ohmmu.com) and four 100w solar panels (Amazon glass). (Coach is pre-wired for solar, but yes, I still need a solar controller/charger, yet to be decided on)
Now, all of this seems fairly straight forward to install and wire, but what I'm not finding on this site and I'm unsure of is, when I'm plugged into shore power or running the generator, how do I ensure my very expensive Lithium batteries are being charged correctly? Is it best to set maximum charge to 90% or another setting, or is charging to 100% okay to do? Also, I understand charging them when they are below 0F can also harm them, so how do I ensure this doesn't happen? The posts I see on charging at low temps suggest a heater pad, etc... But if my coach is in outdoor storage for a month and I go to pick it up, those batteries could be below 0F, unless people are leaving the heating pad on, running from the batteries themselves, using the solar to keep them charged in the off season?????
note: in reviewing the manual for the Inverter, Equalization is always manual, so I don't have to worry about automatic equalization ruining the batteries. The inverter can also be set to turn off at anywhere between 9 and 12.2 volts and I've heard with Lithium, the lower voltage is a better turn off point.
On top of all of this, my coach has an automated generator start up to start up the generator when the batteries get to a low voltage. (I need to do more research on this) Generator uses the house batteries to start, so they need enough of a charge to turn over the generator if in this automatic mode.
Someone else has to have done what I'm planning, so a little guidance would be appreciated.
Kinda depends on your equipment you are using? What are you using as you charger? Does it allow a custom charging profile? First you should consider a 24 volt system and larger solar panels for such a large RV. You should also use a proper starter battery with cranking amps to start your genset and not any type of Li Ion to start your large genset. Li Ion are not starter batteries. Hook the genset to your cab starting battery.
Victron controllers wont charge below freezing or any temp you custom set. And unlike lead dont need to be charged at all in storage. So no worries. If youre using coach in freezing temps you will want a couple $40 heating pads. No big deal, theyre automatic thermostat.
Your magnum converter needs to be set for sealed lead acid or 14.6v. If you can set custom voltages try 14.5v and that will under-charge just right.
Inverter cutoff at 12v is good. Voltage of lifepo4 drops very fast. There little difference in capacity between 12v and say 11.5v.
Id take generator out of automatic mode in storage although it shouldnt be an issue. Just in case deal. It generally is going to be okay at lead acid voltages; on at 12v or 11.8v and stay on until 14.4 -14.6v although you may not want it running that long just for efficiency reasons since you have solar.
This makes perfect sense and is very useful. The LBCO has a max setting of 12.2. I’ll use that. For Battery type, I have gel, flooded, AGM1, and AGM2.
What about the comment above around the generator? I’ve been doing a lot of research and watching YouTube conversions, and no one ever talks about not using the Li-Ion batteries to start the generator. Look at fifth wheel conversions. They don’t have a chassis bank to move generator to.
Are you set on Li-Ion? Have you considered LiFePO4?
Definitely considered those. Haven’t bought yet, but the ones from ohmmu are the same price with 50 more Ah, so I’m really considering those since I’m only wanting two. Getting 300Ah from two batteries would be pretty nice. And for under 2k.
Not sure I understand your comment. This isn’t a new company. They’ve been making batteries for Tesla’s, Leaf’s, and other applications for years.
The chemistry of those types of batteries is susceptible to thermal runaway.
I'm still in the planning stages, but I'm on a similar journey with my recently purchased motorhome: a 97 newmar 37' diesel pusher.
the coach batteries are 4x FLA 12v batteries that the PO replaced under two years ago, they seem to have never had a real workout --PO never had the lids off and the cells weren't low of water. nearly EVERYTHING in the RV works off of this bank (asides from A/C's and washer/dryer) -- the rv didn't come with an inverter. it does have a nice looking 120vac to 12vdc charger.
I plan on leaving the stock 12vdc electrical system alone. it works great, I don't see a reason to mess with it. this way I can return the MH to stock easily -- and if my big battery bank hits the low voltage disconnect I still have a fully charged bank for lights/fans/entertainment.
up front there's a non-functional onan 6500 setup to run off of propane. I have not had time to diagnose it yet.
currently my plans are to ditch the onan completely and fill the large space (where most MH's would have a gas engine) with batteries. I've been hating myself for not going and buying some of those $300 24v lifepo4 packs people are testing on this forum right now. I am also considering used AGM's if I can get a good price on a lot.
I haven't thought much past this so far. do a lot of research and weigh your options. I'm a very frugal (read: cheap) DIY minded person so if I go lithium I'm defiantly going to build packs and the bluetooth BMS's raved about on here.
Id hold off on batteries then. I think prices may fall quite a bit in about 13 months.
Do you plan on charging from the engine alternator? Will generally recomends keeping the starter/engine circuit seperated from the house batteries. However, if you want to charge from your engine, he recommends using a DC-DC charger. This allows you to manage the house battery charge profile independently from your start battery.
So, chemistry is the same, Lithium Iron Phosphate, but the ohmmu are only 4 cell. If there is a chemistry difference I am missing, please educate me instead of just saying they are different.
Sounds fun! Enjoy. I like the idea of replacing the Generator with a large battery pack. This option doesn't make as much sense for me though, based on the type of RV'ing we do.
Well, I have to do something now. Current Lead Acid batteries are dead and won't charge. I could make an effort to revive them since they are only 2 years old. Been reading up on repairing batteries and the RV will be parked for the next 3 months, so there is time to try and revive them and get another 1-2 years out of them while I wait for Lithium prices to drop more.
Something is not adding up. Telsa doesn't use Lithium iron Phosphate.
Precisely which battery are we talking about?
My coach is not wired to charge the batteries from the engine alternator. Engine charges the chassis batteries only, which I plan to leave alone. The house batteries are charged from the Magnum MS-2000 Inverter/Charger, while on shore power or running the generator. Once an MPPT solar charger and panels are put in, the batteries will be charged from Solar/MPPT or MS-2000.
;) Read what FilterGuy says above. Teslas, Leaf's, all EV's have a small 12v house battery. People will upgrade these to LiFePO4 to support higher end amplifiers, electronics, etc....
New member here; joined after seeing this thread because I also have Ohmmu batteries. Mine are not in my RV (yet) but are in a big rack on my wall in the garage which is where my solar charge controllers dump all of my photon-derived electrons all day! We have an "off-grid" system on our house, even though we live in the city and have no lack of infrastructure here. Anyways, we use a 30kWh Ohmmu battery bank and so far have been very happy with the performance.
Saw a couple strange comments though, I'm not understanding:
Thermal runaway? LiFePO4 chemistry is actually known to be one of the most stable around from everything I've read
They are different than what? Every 12V Lithium Iron Phosphate consists of 4 cells, just like every Lead Acid 12V consists of 6 cells; An LFP battery cell has a nominal voltage of 3.2V, a Lead Acid battery cell has a nominal voltage of 2.0V; they are internally put in series to get whatever voltage is needed. The same way we take 12V batteries and put them in series to make 24, 36, etc...
I looked up the Ohmmu and they are indeed LiFePO4
Interesting. I did not know it before now but apparently tesla's do have a 'house battery' that runs the 12 volt electronics in the car.
https://forums.tesla.com/forum/forums/do-ev-have-smaller-12v-battery
"Learn something new every day" Well, that's done. I can go back to bed now!;)
Interestingly enough there has been some discussion on this in the "Tesla world" and EV world in general; the first 100 Tesla Roadsters actually were built with NO 12V battery, they figured it was a good idea to just use the massive lithium battery as the source for all 12V systems as well (as many would assume). However, they learned after a few very costly warranty repairs that the 12V battery acts like a "fuse" of sorts and is actually very beneficial to the overall safety of the vehicle. Reason being; what happens when someone drives their car down to "almost empty" and parks it at an airport for a few weeks while out of town? Well, that 12V system is online and running the entire time, computers are "checking in" with each other, looking for key-fobs, making data-calls back to the "mothership" to see if there are software updates and to provide status updates on the vehicle (so the Tesla app has access to this information when you are away and want to check-in)... So all of this is happening and just running the battery lower and lower, without a 12V there is no good way to stop this from totally draining the main battery pack. It is all deemed "necessary loads" to keep the car connected and ready to drive and even plugging the car in will require the 12V computers in the car to communicate with the charging station to initiate charging (that's right 12V dead? You can't charge the car)... So a few $30K bricked battery packs later and Tesla said "ok, ok we need 12V batteries in every vehicle"
Now that you mention it, I remember the horror stories of Tesla batteries bricking. Now I know why you don't hear those stories any more.
Those were the "early days"... I bricked my share of EV before Tesla even existed so I forgave them (and drive their vehicles now and have a Cybertruck on reservation now!)
