LFP is CC/CV charged. No Float, No EQ none of that. Now some will "Float" at .5V below full level because they have an inverter ON 7/24 and that is always eating a certain amount of juice, in in power save & idle mode.. some are actually pigs too but I won't go there, I learned that one quickly.
Just remember to do your math by calculating at the Cell Level … so 3.60V X # of Cells for example. and use the manufacturer specs for that, they can vary a little.
Rob Beckers of Solacity Kemptville wrote up this article below and did a very good job of putting into plain English for all to understand.
I KNOW Rob personally and they actually have supplied me with a lot of my gear over the years (only a couple of hundred kilometers from me), so I can drive there when I feel up to it.
https://www.solacity.com/how-to-keep-lifepo4-lithium-ion-batteries-happy/ If you follow the guidelines in this doc you won't go wrong and you can tweak to your specific needs / wants.
