5k growatt question
  • Thread starter Deleted member 1888
  • Start date
So while looking at the growatt 5 kw transformer I had been asking questions on that too because my only experience has been with an outback auto transformer years ago, that would step up or down as needed ( and wired ) Im having a hard time finding info on the growatt auto transformer because all the videos and docs refer to using it to split 240 single phase from the growatt 5kw inverter.
So I can see why you mixed them up . most people it seems with this transformer are using it differently than I want too , but it may be easier to get the victron transformer as their wiring diagrams are easy to find and under stand
The victron has a higher capacity, too.
At least, the one that I have heard of.
100a , if I remember correctly.
well, I wish the maker of this transformer had more documentation available. Just found this video.. even tech support at signature solar had it wrong. I ask them could I not supply power N & L1 to get 240 output and they said no.. watch this video I found: "
" ( copy paste the link did not work )
I had already canceled my order with signature solar because of the wrong data they gave me. I thought I was right but hey I'm, not the expert ... anyway I order a Victron through Amazon ( which cost me about 200$ more ) but Im probably going to keep my order on the Victron cause 1 ) Amazon has it now and the other transformer from signature is on backorder 2) Victron did a GOOD job making wiring diagrams available online.
Now the Victron says its rated 100 amps, not sure where that's coming from . cause the manual says 32 Amp or 7.2 KVA , or an unbalanced load of 4.8 kva
spending more money but kinda prefer a company that can produce documentation
If I had seen this video yesterday I would have kept more order with signature solar on the 5 kw transformer
not to beat up on signature solar, I have had good luck with the tech support on the inverter I bought .. just they probably need to get more data on the transfer for their techs
I am currently using that Solar Edge auto transformer.
I like the compact design. And, it just works.
I hear ya , I was looking for someone that could verify it would work in the setup I need but could don't find anyone to concur ( until I found that video , which by then was to late ) . Also when tech support said it could not be used like that... kinda did not want to risk the $$ to get something and not have it work for me, so I ended up paying more $ for the info that the Victron would ..
Well, I said that it would.
But, I understand that you don't know me.
And, it's always good if you can get more people to confirm something. Before you take the chance of wasting money.
It's not that I didn't trust you. I was looking for someone to explain it I.E. = L1 is input 120 volt to transformer and N in N input to Neutral spot , then connect L2 from the transformer as one leg ( L2 ) and the L1 line as the other leg = 240
Then when I got tech support online and they said NO, kinda thought they were wrong,really made me doubt myself
PS I sent the video link to the tech support person I talked with , not as a I told you so, but more of hey maybe something you should know ( to help others )
BY the time I paid Amazon, with free shipping... it only ended up being about 150$ more for the Victron
I am kind of partial to the Solar Edge, I like that it has a temperature sensor.
The victron is a good unit. It will easily do the job for many years.
you know I could be wrong I was also mixing up the solar edge transformer & the Growatt transformer, verify similar ..
So maybe the growatt wont do it but the solar edge will ???
The configuration I am working on has (3) SPF-5000-ES for 15K with 40kW of batteries.
I am planning to install a 3000kw Growatt inverter with about 3K of solar. This inverter will only power the lights and AC in the power shed. I will use this with a Generac 7.5k PowerPac as a genset. It will only run 120V from this config so no transformer issues. So I can program the inverter to start and charge the batteries when SOC drops below a specified percent.
Basically I'm using the inverter as a High Current charger.
Any thoughts or suggestion. I welcome your critique.
