yeah. that was the point (cheaper wire/lower voltage drop).The DC voltage of the solar panels to your solar charge controller has absolutely no relation at all with the AC output voltage of an inverter.
The benefit of high DC PV voltage for the long wire run is that you have lower amps and lower voltage drop allowing for smaller (cheaper) wire.
