Hi all,
Has anyone had issues with using the Growatt 5000 ES battery settings as LI and attaching a comms cable to your battery BMS only for it to cap the charge current well below what the battery is capable of? The only way around this I have found is by setting the battery to User Defined, and that basically throws the SOC out the window because its all over the place.
