HI i got Eve 16Cells with Xiaoxiang BMS have some issues
1) everytime when i charge batteries, the pack don't charge to 3.4 or over. but sometime single cells go over 3.4V. i'm sure this has to do with my BMS settings.
2) or do i have to charge over 3.4V and go up to 3.6V to get the maximum from battery pack? ( i know the safe charging/discharging areas are stay between 2.5-3.6V)
can someone please check my images and help me with proper settings.
when i got the 16cells i checked all had 3.2V and after connecting the BMS total voltage was showing 51.2V
by the way this is connected to Growatt 5000es
Thank you.
Thank you.
