realpinochet
Make Stuff In America Again!
- Jul 4, 2022
- 588
I've been seeing this on youtube with david poz and others and am wondering why this is so alluring? Why buy a bunch of 240V only inverters then have to wire in a transformer to provide the neutral when you can buy inverters already putting out split phase power and just parallel them and combine them at the load center? Wouldn't that be a better option for a few reasons. If the isolation transformer you used to split the phase ever goes out you're without power. If you have five units like in this video and the transformer goes out it's over until you get another one. But if you have five units all running split phase natively you can have all but one go out and still have power..reduced but still have power? A few questions, what's the pull towards doing this? And, does this not turn a HF inverter, or in this case five of them, into LF devices? Does this help with the surge capacity issues HF units have without using a transformer? I looked up the transformer he used and it's between 2500 and 3k. Lastly ...would something like this even pass inspection with or without grid connection?
