timselectric
- Feb 5, 2022
- 19,533
Have to plan for the future. Expecting to have two electric vehicles, in the future.Dam 8 of those things..wow.
Maybe to some degree but I don't think it has to do with just wanting what some youtuber did...which is why I asked the question I did. Doing some research it seems to make sense under certain circumstances. I've noticed that on some of the tier 2 products split phase offerings like mpp you have to buy more than one unit and stack to get split phase. This forces you go buy two units from day one and if one unit goes down you loose one leg.
If you buy a 240 unit you can use one and stack more latter and if one or so goes out you still have full split phase.
Another observation seems to be that the higher kw units are mostly 240V and they seem to be a few hundred cheaper as you mentioned and that adds up for some of us.
Watts247 specifically states, "We do not support the External Auto Transformer Method, as it poses danger of fires when there is a possibility of unbalanced phases, research this topic yourself houses burning to the ground with missing Neutral"Personally, I'd rather go with split phase right out of the box; I'd also rather get a conext, outback or victron system but that's 3/4x the cost which is another reason I think people weigh their options, research and ask questions. Thanks for your input...you have good points.
Absolutely not. A LF inverter needs the transformer for harmonics (among other things).When you use a transformer like this, auto or isolation, does it help the surge capacity of a HF system since you're adding a transformer after all?
Watts247 has them listed for $588Sig Solar shows the 5000ES at $900 x 3= $2700, the EG4 is $1300 x 2= $2600. The 5000ES requires a transformer, additional $350. Where is the savings
X3 = $1764
+ transformer $350 = $2114
And you get 15k balanced output, and 300a solar charging. And if one unit goes down, you're still up and running at 60% capacity.
It's not expected to handle 15kw.A $350 transformer isn't rated to handle 15kW. If you're depending on your superior load balancing skills in the breaker box to keep the load under the 5-6kW the transformer is rated for you're going to have a bad day at some point in the future.
As long as you are not limited on space. A few more panels takes care of it.What about the high load consumption of the Growatts/MPP inverters or is that not an issue for most? I thought they had a no load consumption of 80-100 watts per inverter which would really add up.. that's about double what a "higher quality" inverter's no load usage is.
I can relate to this already. I got a Conext 4024 SW inverter as a stand-alone unit, with the idea that I might double capacity at some point to run my well-pump. I bought the 2015 model that "says" is has paralleling capacity. Fast forward to 2020, and paralleling has been taken out of the 4024s features.Think about this with stackable units, especially in split-phase. What happens a few years down the road when one dies, and you can't find the same model, or hardware/firmware version to replace it?
Technology moves fast, and companies are always coming up with new products to replace the old.
Cost and expansion, you can put up to 5 units together if you want.I've been seeing this on youtube with david poz and others and am wondering why this is so alluring? Why buy a bunch of 240V only inverters then have to wire in a transformer to provide the neutral when you can buy inverters already putting out split phase power and just parallel them and combine them at the load center? Wouldn't that be a better option for a few reasons. If the isolation transformer you used to split the phase ever goes out you're without power. If you have five units like in this video and the transformer goes out it's over until you get another one. But if you have five units all running split phase natively you can have all but one go out and still have power..reduced but still have power? A few questions, what's the pull towards doing this? And, does this not turn a HF inverter, or in this case five of them, into LF devices? Does this help with the surge capacity issues HF units have without using a transformer? I looked up the transformer he used and it's between 2500 and 3k. Lastly ...would something like this even pass inspection with or without grid connection?
Actually 6.Cost and expansion, you can put up to 5 units together if you want.
Sig Solar shows the 5000ES at $900 x 3= $2700, the EG4 is $1300 x 2= $2600. The 5000ES requires a transformer, additional $350. Where is the savings?
