Hi our Trace inverter has temp sensors which were attached to the old lead acid batteries. I do not know if they are needed with the new batteries, nor how to turn them off. Also there is a selection in the inverter's charging section between lead acid and nicad, and no apparent off switch. Does anyone know about these things? The paper manual has been well examined and I see nothing about a bypass or auto sensing.
