jsmetalcraft
- Jul 7, 2021
- 188
Help me out, what is "baking off a break"?
Haha.. typo... bread. From europe so real bread monsters. We don't like the sweet US bread, so we make/bake our own bread every other day.Help me out, what is "baking off a break"?
Smart, we should try and do that as well.Mom made bread growing up grinding her own wheat, and wife made bread for us but used a bread maker machine. I don't care much for most breads in the stores. Now I eat as little bread as I can due to carbs,
Necessity, but also smart.and as little sugar due to pre-diabetes.
- name: "Daily Bat Charging"
class: "energy"
state_class: "total_increasing"
uom: "kWh"
scale: .001
rule: 1
registers: [0x316D]
icon: 'mdi:battery-arrow-up'
- name: "Daily Bat DisCharging"
class: "energy"
uom: "kWh"
scale: .001
rule: 1
registers: [0x316F]
icon: 'mdi:battery-arrow-down'
I played around with Home Assistant today and added daily battery charging & daily battery discharging to my setup
def main():
modbus = PySolarmanV5(
"192.168.X.XXX", 233XXXXXXX, port=8899, mb_slave_id=1, verbose=False
print(modbus.write_holding_register(register_addr=5120, value=0x####)
if __name__ == "__main__":
main()
Would you mind sharing your .yaml config file with us/me ?Looks good! This is what I have logging in my HA so far....
This is my charge/discharge graph
I tried all but doesnt find a way to get the read on solar asistantYou can get the RS485 signal from the ethernet port I guess. Not sure if there is any suitable PC software.
Did you end up getting work on solar asistant ?@jsmetalcraft - you'll need to find a circular 4-pin adapter to plug into the slot where the Solarman (IGEN) stick-logger goes. Circular Connector: Pin 1 = Positive 5 Volts, Pin 2 = Ground, Pin 3 = RS485+, Pin 4 = RS485-. For the life of me, I can't find out what the spec of the adapter is to order one. You can then just use a Raspberry Pi or similar with the Waveshare RS485<->Ethernet adapter and pymodbus to hoover up all metrics from the Megarevo. Some folks have done some pretty neat graphing of the metrics.
I am still missing so much information , and my oem reseller is pushing MR to update their info but no response yet.Once the firmware upgrade enabled proper data collection using the WiFi dongle, I stayed with the pro.solarmanpv.com site.
Can you tell us your settings please ?My unit's been running in Peak Shift mode (or Weak Shift according to the display) for a few months now and has been doing the right thing.
Thank you for all your information/feedback!My battery at home right now is only 6kWh (going to switch to home-made 14kWh or just buy a 25kWh system).
I am very confused by the wording/settings in the menu of the MR.The chart below shows peak shift working. The battery gets recharged at midnight during low power time and grid power is used to drive the loads until the start of peak time at 7am, then the battery is used until the PV system recharges it and also powers the loads. The battery is not touched until there isn't enough PV in the evening. I've actually turned off grid usage until 9pm (mostly just to not use grid when the dishwasher is on after dinner).
I have the Work Mode set to Peak Shift with Time 1 and Time 2 set.
Time 1:
Charge Start: 00:00
Charge End: 07:00
Disc Start: 07:01
Disc End: 22:00
Time 2:
Charge Start: 11:01
Charge End: 17:00
Disc Start: 17:01
Disc End: 19:00
What I'd done is try to balance the charging with the TOU periods. Time 1 is saying charge from the grid between midnight and 7am and discharge time is 7am to 10pm (not 9pm as I said before). The Time 2 setting is saying that you can actually charge from the grid during mid-peak pricing (11am-5pm, peak being 7am-11am and 5pm-7pm) if you have to - but I've actually not seen that as yet (my loads aren't big enough).
The :01 times are necessary otherwise if you say, for example, Charge End: 07:00, Disc Start: 07:00 - then the unit just gets confused.
I did encounter some weird behaviour when I turned off anti-reverse and let the unit power the grid. The main AC and dryer are not powered by the Megarevo and when I did my test, the dryer was going. The unit kicked into high gear and the fans sounded like jet engines and the battery started dumping at 200A and triggered an overload warning. I'm not entirely sure why the battery was being used to power the grid. I know somebody mentioned it in an earlier thread (jsmetal maybe?) and perhaps that's why you need to dial back the percentage fed to the grid.
