I was told the parallel stacking support is not there yet. Its being worked on and will come as a firmware update. For the foreseeable future I’m thinking the firmware updates will be frequent.
"I was told" always starts to ring bells with me.
There is no source, not any kind of foundation with such a statement.
Please tell me where you got it from, preferably in writing.
I can tell you this about an other inverter: megarevo
When I bought it, it had nothing mentioning paralleling multiple inverters in the datasheet.
After using it for a while, I gave feedback to the oem reseller and of the things I said was "i wish it could be paralleled for more power like eg Sol-Ark"
The response was: "Paralleling is now enabled, if you install the attached firmware"
So yes, firmware does fix a lot of things.
In case of the LuxPower/GSL branded hybrid inverter, it already says it can work with up to 10 inverters in parallel in writing in the spec sheet.
So the fact you tell us "you were told" does not make me believe your statement.
