It's on the 1st page of the Advanced screen, right in the middle, to the right of "Seamless switch".Where is that ChargeLast flag might be?
I couldn't find in the server app.
I did talk to Jim about getting him a box. Jim just laughed and said a single inverter is too expensive. I sent him the review of the 15kw Sol-Ark that Will did and suggested he look at the number of subscribers to Will's Channel. didn't hear back from him.Can anyone get in touch with Will Prowse? There are 28 pages on this thread and probably over 500 posts, and still growing
It seems that there might be enough interest that maybe, Will P. would consider doing a review of the GSL-H-12KLV-US hybrid inverter..
I have the same problem. It always reset my time to 1 hour later as if it's a day light saving time.Even though I set the timezone correctly, it seems to ignore my timezone and gets the time from internet
I think I found a way to fix the time zone.I have the same problem. It always reset my time to 1 hour later as if it's a day light saving time.
I remember somewhere when registered a monitor account it asked me to set up a daylight saving flag.
But I can't to find a way to change that yet.
in the inverter itself? on the app ? on the web ?I think I found a way to fix the time zone.
It's in configuration menu
Select and edit "station"
select the time zone and daylight saving option.
On the webin the inverter itself? on the app ? on the web ?
And let me know if it lasts longer than a couple of hours.
Mine keeps switching back to a different time zone
Figured it out.On the web
The time zone is controlled by the station setting not the one in the user setting.
Same hardware as Sol-Ark 15k.I agree with Hrschk, same as what??? I have done extensive searches trying to find whole house solutions with a 200A bypass, so that the on-grid power available is not limit to the off-grid power. If you are looking at MPP Solar or SunGoldPower hybrid inverters read their identical manuals, they want a 40A disconnect between the hybrid inverter and the grid. Genrac, Huawei, Sol-Ark and GE new hybrid inverters are just so expensive. I would love to see some more competitive options for hybrid inverters with whole house backups. Please share.
I set the LastCharge flag now. But it didn't turn on AC charging during the set intervals. Will wait until the sun comes up tomorrow to test PV charging.I had the same problem (charging did not appear to stop), but I do not believe GSL support understood my concern. Anyway, in my case, I set the 'charge last' flag in addition to the PV charge priority time period (sorry, not near my inverter for the exact wording). Seems to work OK - I now have to tell my inverter when it is OK to charge.
Also, be careful when changing any settings while in between a start/end time. When my batteries did not stop charging, I remember also changing one of the limits and nothing else. It is completely possible just by saving the new value, the inverter "forgot" it is in the middle of a schedule. I have not tried to re-test this theory.
Which is a lot for a product that is being sold/installed imo.I feel better knowing that the issues so far are limited to only paralleling inverters, generator connection, AC coupling, BMS, and accurate readings.
the LV6548 is a MPP inverter:If I upset you, I apologize.
I did a Google searched LV/SP/EG6548 and there were no results and only received one page of ads. As I said, I have done extensive searches trying to find whole house solutions with a 200A bypass as the Sol-Ark 15K or the GSL-12K. I know new hybrid inverters will constantly be coming to the market, so I was very interest in another choice or your find. The expression same as what was a serious comment, I don't know what brand and model number your post is referring.
I'd add excessive idle consumption to the list, although for everyone's sake I hope the reported numbers improve with updates or usage.I feel better knowing that the issues so far are limited to only paralleling inverters, generator connection, AC coupling, BMS, and accurate readings.
We have to remember that this inverter still hasn't been officially released. It doesn't even have their name or colors on it yet. I am not trying to defend GSL or the inverter, I am trying to remind everyone here that they said that the inverter supply would be ramping up by November. I guess that they were expecting to be done by November with all of the firmware features, but as usual with almost all software they encountered unanticipated problems in addition to the anticipated problems. They will need time to get through these things, and according to their only estimate so far, they still have at least two more weeks. They probably won't make that date for every problem, and may not make that date for any problem, but that is when we can start saying legitimately, "Hey you sold me something that doesn't work". I appreciate all of the early adopters here. You are essential/unfortunately providing beta testing for the inverter and GSL and all of the rest of us, and in the process you are identifying all of the most critical issues that need addressing. Thanks for being part of the engineering team. I'm rooting for them because if they can polish this up the way it needs to be, it becomes an alternative to what is out there. I am most concerned about hardware problems. If those exist and are exposed, then we will know it is a dud. So far I think everything that has been reported has been a configuration problem or a firmware problem. If I am wrong let's get them out front. Idle power consumption might be the first one on the list.I feel better knowing that the issues so far are limited to only paralleling inverters, generator connection, AC coupling, BMS, and accurate readings. (and idle consumption)
I just checked mine after i saw your post from FAAA-0B0A-> FAAA-0D0AI got a firmware update tonight:
Firmware version is still FA 1.0
Build version went from FAAA-0B0A -> FAAA-0E0D
Hopefully more success for me tomorrow
Did they do it for you automatically, or did you have to do it yourself?I got a firmware update tonight:
I contacted the dealer I bought my inverter from, who gave me the feedback about the firmware update regarding parallel setup.Did they do it for you automatically, or did you have to do it yourself?
The firmware was automatically updated by the factory? You didn't need to upgrade the firmware yourself using your laptop or your phone?I contacted the dealer I bought my inverter from, who gave me the feedback about the firmware update regarding parallel setup.
He was in contact with LP and he asked for firmware update to be sent to my unit.
Nothing like upgrade of the MR with the USB-C cable and a laptop ;-)
