Pvoutput.org integration would be good.In no specific order of importance:
- I'd like better documentation on how the Home Assistant inverter controls work. I have SA integrated in HA but see nothing about being able to control anything from HA.
- I'd like to be able to export data from the totals tab, and for some control on what the total tab shows. At the moment it is fixed.
- Output integration with PVOutput.org
- On the dashboard I'd like to option of displaying battery power on the primary chart along with PV, load and grid power.
- I'd also like the battery icon to show the voltage.
Mine are all positive.So on my Sol Ark and my battery BMS seems all my temps are reported as negative values. Not a big thing but would be nice if they were reported as positive temp values
What BMS are you using?Mine are all positive.
JBDWhat BMS are you using?
Yes I tried the splitter but it will not work with fortress batteries because the 485 port is closed to other devices once you change the Sol-Ark to anything other than Lithium mode 0. My batteries require Mode 4.@robby I remember reading you were upset about the SolArk not having a 2nd port to have batt comms and Solar Assistant connected at the same time. Have you looked into the splitter that Solar Assistant recommends? I bought one on Amazon for $1.61 including shipping and it showed up next day
See the bottom of the page:
Configuring Deye/SunSynk/Sol-Ark inverter
How to configure a Deye/SunSynk/Sol-Ark inverter in SolarAssistant.solar-assistant.io
The splitter I bought:
Atleast its in progressWell, no luck, yet. This is the response from SolarAssistant:
Configuration, advanced and then dashboard display and change from 5,000 to whatever you need there.Anyone noticing that the “Load” gauge is getting stuck with the latest version of SA?
The red band will fly half way up when I am drawing 5000W and stay there even if the load drops to 1KW. If I scroll the screen a bit it unfreezes.
Yes i have the scale set to 10KW but the problem is that the Band now gets stuck at one reading even though the Numeric Wattage reading is charging drastically. This was not happening until I upgraded and it only happens on my Tablet. All other gauges work fine.Configuration, advanced and then dashboard display and change from 5,000 to whatever you need there.
Can you try another browser on your tablet? Just to narrow it down and maybe give them more insight as to what to look forYes i have the scale set to 10KW but the problem is that the Band now gets stuck at one reading even though the Numeric Wattage reading is charging drastically. This was not happening until I upgraded and it only happens on my Tablet. All other gauges work fine.
Well, after reading a post where it was possible to get a Growatt sc4880 charge controller communicating with a Growatt spfxxxxt all-in-one, I sent another email to SolarAssistant and got this reply:Well, no luck, yet. This is the response from SolarAssistant:
There are no options for charts colours AFAIK.I'm not sure if this is the right place to ask this, but is there a way to make the graph colors in the charts tab persist ater logout and login? Currently, i end up setting new graph colors to be able to tell the difference every time i log in. Then the next time i log back in everything is back to system defaults which are mostly yellow for everything.
