EG4-6500 switch from battery to utility
EPicTony
NE Ohio
My split phase EG4-6500 has been running for 36 hrs now. Yesterday it was partly sunny and the EG4 battery SOC got up to100%.
It ran all night and today was very dark so the PV didn't do much at all, basically running on battery all day. The SOC got down to 15% and now the utility is charging the battery and running the inverters. What determines when the inverter switches back to battery (parameter 13)? Charger priority is set to solar first (parameter 16).
What is the recommendation for parameter 12 & 13 when using the EG4 batteries ? Thanks for any advise.
It's really personal preference.
How much battery you want to save for emergencies.
I have mine set to stay above 25%.
It's recommended to stay above 20% for a healthy and long lasting battery.
I run mine 48V to 52V for pass through charging. I like to keep some in the bank for backup. I have a very large bank (105kWh) so charging to 52V is fine.
If I know a big storm is coming, I will bump it up to 56V to charge the bank the day before.
While I don't have the EG4 batteries, I run mine similar to @PreppenWolf. It's really up to what you're desiring to get out of the system.
What values do you guys run in options 12,13 and 29 when in USE? With solar assistant and eg4 batteries, you can't use the SOC option true? Can I get some of your settings please?
At the moment, I have mine set to 12-48, 13-55, 29-46. I am constantly playing around with different values though to try and find the optimal ones for my setup.
As far as I know, unless you have your batteries hooked up to the inverters with one of the acceptable protocols (ex. EG4), your inverters can only make changes based on voltage, not SOC. That's why I use Solar Assistant because on the "Power" tab, Solar Assistant can change modes based on the SOC. It just pushes the change to the inverters when the thresholds are hit.
This is my current settings.
Charging might be too aggressive for most people.
Nah. Everyone's gonna tell you something different and everyone's gonna tell you why they're reasoning is right. There's probably a little truth to everyones positions, but ultimately it's your decision as to how you want to charge your cells.
I keep changing mine. Used to charge them up to 56.8 and might do that again...never know.
Option 12 (back to util) 48V
Opt 13 (back to Batt) 49V
16 OSO (solar only charging)
26 (bulk V) 58
27 (float V) 54.5
29 45V
These settings were chosen to optimize solar system production, while limiting some reduced life of the batteries. If we need more UPS reserve, I would bump option 13 to 53V so as to have a battery reserve.
I don't understand why JCSchwarb's settings:
26 (bulk V) 58
27 (float V) 54.5
29 45V
are so much different than yours, it's like night & day different. Are both of these for EG-4 batterys ? Especially param 12 ( 48v vs 51.2v) . Thanks
26 (bulk V) 58
27 (float V) 54.5
29 45V
The big differences I see are one is set to optimize solar production to lower electric bill while the other settings are for a UPS where one wants to ensure they have backup.
26 (bulk V) 58
27 (float V) 54.5
29 45V
It's mostly personal preference.
And what you want out of your system.
Both are 48v LFP batteries. Brand doesn't matter.
I'm confused. I have JCSchwarb's settings and at 52.6v it switched to grid. I don't get why it switched. Isn't it supposed to switch at 48v (option 12) ??? I also just checked and its set for SUB (changed by solar assistant), is that why ???
Do you have that feature enabled in SA?
I have SBU priority, not SUB.
I think the SA power management feature made the change for him.
I’m actually running a test right now to see what happens if you have the SA power management feature enabled and you have options 12/13 set to values that could trigger the inverter to change modes before SA “wants the change done”.
Spoiler alert.
It will switch according to whichever setting tells it to, first.
SA just acts as a remote control. The inverter sees it the same as if you manually changed something from the inverter screen.
Spoiler alert.
Yes and no. I need to try and repeat the test but it looks like if the inverter tells it to switch, SA might switch it back. The voltage drops because charging stops during the switch, which could then cause the voltage to be under the value set for option 13. Then the cycle begins again.
Very annoying till you figure out that’s actually happening. Just need to try and repeat it.
Do you ever see Grid Ac in being used even when plentiful Solar is available? Today I had 2.5 KW coming in to each inverter and battery was around 54 volts and inverters were still accepting voltage from grid Ac in. I turned of grid AC in and PV input jumped up on each inverter to 3.5 KW. I hate to be wasting PV during the day.
Are you saying if you are using SA for those settings then you change it manually on the inverter that SA changes the settings back? I'll be interested in your test results.
That can happen if the low and high settings are too close. No matter which device is controlling the switch.
