Texas-Mark
Solar Addict
- Aug 4, 2021
- 1,311
So you are thinking something like this-
shaft > car alternator > 12v battery (like a car battery??) > CITYORK 12 Slot LCD Smart Rechargeable Battery
Any fuses along the way?
Yep.
Fuses between alternator and battery (based on size of alternator) and fuse between battery and charger should do it.
Another benefit of the car battery is you can use it to power the AA chargers quite a bit before needing to run the alternator.
What I don't know is what the minimum alternator rpm that is needed to generate a usable charge current.
