Wish List
1. App or Firmware Update so that the AC Limiter Stays on Between Cycles (aka turning the unit off and back on either manually, scheduled or because the mppt timed out due to lack of solar power resets the AC Limiter to OFF)
2. Same for the Head Unit "Light", Fan Speeds, etc. Right now, if the head unit light is off, when the unit powers off and you turn it back on, the "Light Off" setting is not remembered and it comes back on.
3. In some cases, the Unit seems to go to sleep and has to be physically restarted IF running on DC solar input only AND solar availability gets diminished below the input threshold of the MPPT.
- IF the sun goes behind clouds long enough for the MPPT to time out its search for solar power
- In some cases, The Unit simply will not start back up and power back on once the sun come back out (when running on DC solar only: AC breaker off or not connected)
-The unit times out, and ...
- You have to physically turn it back on.
4. The room temp and the set temp seem to diverge a good bit. Example: if the unit is set to 75F, it will run the compressor to about 73F and then not come back on until the room gets to about 77F
5. App Updates
- Cloud Scheduling (which you to set an On / Off time schedule): Would be nice if the scheduling could also include settings for
- Temp when the unit comes on so the User could set different temps for different times of day
- Same for the AC Limit Function, Fan Speed, Head Unit Light, etc
What else does anyone else see / Wish for?
