Just installed a 48v 400 aH LIFEPO4 bank and orion jr2 BMS. The DC current is highly variable. Screenshot below. There is some solar charging going on while the inverter is also powering some loads. I sent this image to the tech support of my Magnum inverter just to make sure this was normal. He said it was. Do any of you have similar "noisy" charts when monitoring current at a high sample rate?
