Another new hybrid inverter. Aims PIHY9600 660v pv input , touch screen, 15kw pv
1201
Solar Wizard
Texas
Such a great time for diy pv. Competition is heating up! Check this one out! $3600.
Hybrid-Power-Inverter-1000x1000-copy-01-600x600.jpgMicrosoftTeams-image-9-1000x1000-20230319-1-600x600.jpg
  • Listed to UL 1741-SA I CSA 22.2 No.107-01 I UL1998 I UL1699B
  • Stackable (Max 6)
  • Direct 3 string PV input
  • IP65 NEMA4X rated for outdoor installation
  • 10 year warranty
  • Customizable DC input voltage for various battery types including lithium and lead
  • Free USA based tech support
  • Wide programmable voltage input range
  • Generator input for backup 240VAC
  • Wide PV input voltage range
  • Load sharing
  • Isolated emergency backup output for defined loads
  • Configurable charge and load times based on local utility recommendations
  • Loaded with safety features
  • Large 5-inch color LCD
  • RS485, CAN, Wi-Fi, 4G
  • Extremely efficient
  • FCC Part 15 Class B
Seems like a nice unit for the price and features. Looks like shipping should be under $100 for the continental US.
My favorite part is the name / naming convention, I bet @timselectric agrees ?.
I still wouldn't trade my SRNE for it.
I'm not sure what the name is.
I do see where it says "hybrid" but talks about off grid.
Not sure if it's actually a hybrid.
I don't think there's any real competition for the srne right now. 10kw split phase for 1400 is untouchable.
This one might compete with eg4. I just don't know yet if it's competing with the 6000xp or the 12kw 18kpv.
It can export to the grid which 6000xp can't do, but can it ac couple?
Pihy9600
Are there any low cost inverter suppliers that actually stand behind their product?
Not really. At least not consistently.
I don't care about warranty, or customer support.
My system has proven to be reliable. And if I ever do have a problem. $600 replacement, puts me back in business. Without any arguing or red tape.
And zero downtime.
This looks super similar to the Deye 8k i have, inside the wiring cabinet part.
I'll have to take a look at that. Btw, just checked cec and they are listed!
Edit-
Just another closed communications high voltage inverter.
From the manual:
The PIHY inverters are compatible with AIMS
Power lithium batteries only
(Part #s:
LFP230V96A-M & LFP230V96A-S) and the
lithium charge default setting is for the AIMS
Power batteries. Also compatible with all lead
acid battery types (gel, AGM, open). If you
prefer to use a different lithium battery you
MUST contact AIMS Power tech support to
check compatibility and charging programming.
No exceptions.
BYW, , the Solis S6 has full listing including UL9540 and more power options for similar price range
From the manual:
(Part #s:
No exceptions.
Curious, Will the Solis work with lead acid and agm?
No on the S6
Trying to use agm / lead acid in long series strings is problematic at best. Also , for 9600 watts your looking at ~240V battery minimum, 80V is just a wake up voltage likely.
No on the S6
The thought is if it will work with lead acid then it should work in open loop with diy lifepo4 packs
The issue with open loop LFP is the BMS is crazy expensive when you start getting to cell counts over 24.
Stacking BMS will end in blowing up if one disconnects and the load pulls the remaining string batteries to ground ( load ) or max charge voltage ( charging ) leaving a large differential potential the BMS can not handle. This is why the 12V batteries limit to maximum of 4 ins series.
I've been 3 years now into a UL9540 HV system ( Solis BYD ) and while there are strong advantages the low current provide, DYI batteries for high voltage just are not affordable since there are only a couple of options on BMS and then it is similar cost to use full UL9540 solutions, like BYD , Pylontech and the like.
Surprised no one noticed this part:
So use an EV battery pack at 380vDC? problem solved??
but use the EV battery instead of trying to DIY a high voltage pack from cells,
Avoid this cost using 380v EV battery pack which has it's own BMS built in?
No stacking needed ? Parallel identical EV packs?
