Solar Guppy
Red Cobra Guppy
The thought is if it will work with lead acid then it should work in open loop with diy lifepo4 packs
The issue with open loop LFP is the BMS is crazy expensive when you start getting to cell counts over 24.
Stacking BMS will end in blowing up if one disconnects and the load pulls the remaining string batteries to ground ( load ) or max charge voltage ( charging ) leaving a large differential potential the BMS can not handle. This is why the 12V batteries limit to maximum of 4 ins series.
I've been 3 years now into a UL9540 HV system ( Solis BYD ) and while there are strong advantages the low current provide, DYI batteries for high voltage just are not affordable since there are only a couple of options on BMS and then it is similar cost to use full UL9540 solutions, like BYD , Pylontech and the like.
