That's quite a jump. I'm guessing that the batteries are close to full. And not actually 71%.2x 280ah lifepo4 batteries
200a jk bms
victron shunt
currently sitting at 53.3v and 71% soc
i have charging set at 50a and within 3 minutes it will go from 53.3v to 55.2v and stop charging.
is this normal?
Actually that doesn't make sense, either. With only 50a charging.That's quite a jump. I'm guessing that the batteries are close to full. And not actually 71%.
That's what I thought(too fast).That's quite a jump. I'm guessing that the batteries are close to full. And not actually 71%.
What charger and what is the charge profile?i have charging set at 50a
What are your smart shunt settings? 3.33Vpc at rest (these voltage are measured at rest, right?) is higher Soc than 71% in most my batteries.I discharged to 70% today via smart shunt so I believe it's accurate
i can. its the jk bms and it doesnt log the data that I know of . Later today I will go to the shed and see if I can monitor in realtime. yesterday I was able to charge at 40a and Ive been charging at 35a from solar today but at 50a voltage just goes sky high.Actually that doesn't make sense, either. With only 50a charging.
Can you access the BMS data? Maybe they are shutting off, due to a high cell.
ill have to write the charging profile and post it later.What charger and what is the charge profile?
If you do not have a long absorb cycle, then your cells resting voltage may be near 3.35V (53.3V / 16 is 3.33Vpc so not far off that). So if you share your charge profile, a lot of that info will narrow down and explain what you are seeing.
Yes, need to monitor it as it's happening.i can. its the jk bms and it doesnt log the data that I know of . Later today I will go to the shed and see if I can monitor in realtime. yesterday I was able to charge at 40a and Ive been charging at 35a from solar today but at 50a voltage just goes sky high.
Thanks!Hey, we all do silly things. You are not alone in this.
