I've had a good crack at implementing Will's blueprint with the addition of a Renogy battery monitor and a Bayite as a total DC load monitor. I hooked it all up to car as follows, 4 gauge wire everywhere (minus the solar and solar shunt/ monitor as don't have the panel yet) and spent time with some free software getting this swanky wiring diagram together, but I suffering a reverse polarity situation according to the battery monitor.
Are these settings the recommendation of Fortune 100aH cells combined for 12v battery ?Jbamps, you might want to start another thread with your questions. This is not a BMS thread.
So, looking at making a custom user profile for my Fortune 100aH cells. How does this look?
HV disconnect : 16
Charge limit voltage: 15.5
EQ- 15.5 (but we do not want an EQ on LFP)
Boost : 14.6 (manufacturer states 3.65 per cell, is this a little hot?)
Float: 13.8
Boost Char Return: 13.2 (I assume this is when it goes back to boost from float)
Low voltage alarm : 12.1
Over discharge volts: 10.6
Thanks!
@RandyP if the starter is chassis grounded and the starter negative is connected to the DCC50S neg and the LiFePO4 neg is connected to the DCC50S neg that mean that the LiFePO4 is connected to a chassis ground - right?The wiring is a little 'different', but that's OK.
The switch in the - wire from the start battery, I don't see that often. I'd suggest you put that in the + wire from the start battery.
I see that the starting battery - is chassis grounded. The LiFePO4 - should also be chassis grounded.
Wire from - LiFePO4 should go to the - bus bar.
Wire from solar panel - should go to - bus bar.
I would add a small circuit breaker switch to the + circuit from the solar panel to the DCC50S + solar input. That way you can isolate the DCC50S from the solar panel.
I would use a small circuit breaker/switch in place of the fuse in the wire from the LiFePO4 + circuit to the DCC50S +. That way the DCC50S can be easily isolated from the LiFePO4.
I do not know why you are getting incorrect polarity indications.
in reference to the renogy DCC50S does anyone know if the BVS cable should go to the service battery or the starter battery?
Sure, but the ground should be short, same gauge wire as the Battery + wire. One ground for each battery. It's a current return path for 12v ground faults to clear the batt main fuse. You do not want to run that current thru multiple termination points and devices. It's a code/standard and safety thing. In your mind it might be the same as what you have now, but in realty it is not. Logic is not the only thing you apply for electrical safety. If you comply with codes and standards fr safety, you will be safe.@RandyP if the starter is chassis grounded and the starter negative is connected to the DCC50S neg and the LiFePO4 neg is connected to the DCC50S neg that mean that the LiFePO4 is connected to a chassis ground - right?
Manual says start battery. It is used to get start battery voltage for control. The current carrying wires from the start battery have a voltage drop across them, so a dedicated circuit for battery voltage is required.in reference to the Renogy DCC50S does anyone know if the BVS cable should go to the service battery or the starter battery?
Check Votronic VCBS https://www.votronic.de/index.php/en/products/battery-charger-series-vbcs-vac-tripleCharging from Alternator and solar panels, plus, is there any option for adding AC charging capability?
It will be the ultimate solution for my RV.
Greatly appreciate the responses here guys. I also reached out to Renogy support and they have since replied as follows:I just checked the manual and I don't think it says "starter" battery.
It does show a picture of a battery with an RV on it though.
I guess the dc2dc charger cares what the voltage is at the starter battery because it actually charges the starter battery once the house battery is topped off.
My mistake, not good with pictures.
Ok great, that makes sense @RandyP many thanks.Sure, but the ground should be short, same gauge wire as the Battery + wire. One ground for each battery. It's a current return path for 12v ground faults to clear the batt main fuse. You do not want to run that current thru multiple termination points and devices. It's a code/standard and safety thing. In your mind it might be the same as what you have now, but in realty it is not. Logic is not the only thing you apply for electrical safety. If you comply with codes and standards fr safety, you will be safe.
"Hi Harley,
Thank you for contacting Renogy support.
The battery voltage sensor is to be connected to the house batteries."
Ticket ID 164011
I had the BVS connect to the starter battery yesterday and the voltmeter showing house battery (105Ah 12V LiFePO4) voltage went crazy and showed voltage climbing, it got up to 17V then I shut everything down. I'll try BVS connected to house battery later this morning.Wow.
Renogy agrees with me but @RandyP convinced me that I was wrong.
In a typical setup I don't see the reason for sense leads to the house battery because it will be pretty close to the dc2dc charger.
The starter battery however could be a significant distance away.
Can someone more neuro-typical than I am have a look at the pictogram in the manual?
