From above:Looking at the Renogy site for that, it had a pic of the compatible devices and the DCC50S didn't appear to be in that pic.
Here's the info from Renogy on the BT-2:
" Meet the Renogy BT-2 Bluetooth Module! Unlike the BT-1, this new generation of Bluetooth Module is compatible with a variety of products, including Renogy solar charge controllers, smart lithium batteries, inverters, and DC-DC MPPT battery chargers. Connect the BT-2 to the component's RJ45 communication port to wirelessly check and adjust your system's parameters through the DC Home App (available in both the App Store and Google Play)."
Here's some more info:
Renogy BT-2 is a new generation of Bluetooth module for Renogy solar charge controllers, smart lithium batteries, and inverter chargers, providing wireless monitoringwww.renogy.com
I have a BT-2 but haven't plugged it in yet.
Also if your starting battery positive cable has a blocky looking thing for a batt terminal cable clamp, rather than a simple battery terminal cable clamp... you probably have a smart alternator...BUT the best technical answer is described above by using a voltmeter.The DC-DC charger doesn't care what the starter battery chemistry is. The House battery has to be one that the DCC50S has a charging profile for. It can be a SLA, GEL, FLD or Li chemistry battery.
Put a voltmeter on the alternator or starting battery. Start the truck and let it run. If the voltage settles at about 13.2 v or higher after recharging the battery after the start load, its a standard alternator; If it recharges the battery then voltage drops to about 12 v, its a smart alternator. Seems that with some google effort, looking at vehicle specs, maintenance processes, you should be able to figure it out. But the volt meter will tell the tale. You can hook it up either way and see how it works when you get it. A volt meter is your tool of choice for installing the device anyhow.
The best settings are battery chemistry and Mfgr dependent. Start by checking the battery mfg specs for charging and maintaining the battery you use.I got my BT-2. Hooked right up to the DCC50S. You do have to enter a password to change settings. So, what is the best voltage setting for the boost voltage?
"COVID-19: We are open and accepting orders for delivery within the UK, but our checkout is closed from 12pm Friday to 9am Saturday. We are currently not offering UK next-day or international shipping services. For full information on how COVID-19 is impacting ordering and deliveries, please click here. "Plain Copper Battery Cable For Auto & Marine Use | 12 Volt Planet
Plain copper battery/starter cable suitable for low voltage auto and marine applications. High temperature, high flex and siamese types available.www.12voltplanet.co.uk
Is this a good place to get the cables for my system please?
Ive bought from them, seem decent enough and quick. Im in the UK btwPlain Copper Battery Cable For Auto & Marine Use | 12 Volt Planet
Hows it working out for you now ?I got my BT-2. Hooked right up to the DCC50S. You do have to enter a password to change settings. So, what is the best voltage setting for the boost voltage?
The fortune battery specs say 14.6 for the absorb/boost voltage, is that a little hot?
I don't know about android, but The iPhone app Settings are on the settings page (little gear symbol on bottom of screen takes you there. Then select the 'Battery' button (second row of buttons on top of screen). Then select the read button (top row of buttons). Under General Parameters (near top of screen) there is 'System Voltage' and 'Battery Type'. Select the battery type right below the heading 'Battery Type', its blue on the iPhone. It will ask please input password, select confirm and provide password (that sequence of odd numbers up to 9 the 0 123). select confirm again. It will respond 'Pass Word Correct'.So, I just went out there and I still can't find a "user profile". It won't let me change the float voltage, which is the one parameter I really want to change. Any idea where to find it, I am using the Android app.
That change is what drove me to get the BT-2, I did not like the 14.4 float that seems to be the 'LI' profile setting, that came stock in the DCC50S........... the float voltage, which is the the one parameter I really want to change...........
Wow way to hook the up-sale Renogy. ?That change is what drove me to get the BT-2, I did not like the 14.4 float that seems to be the 'LI' profile setting, that came stock in the DCC50S.
