I'm planning on building an off grid 12kW system with 30kWh battery.
The panels I'm looking at have an open circuit voltage of ~50V and I was going to create two strings of 12 panels each, but I can't see many MPTTs accepting 600V, so maybe I need to limit myself to 9 panels per string, 10kWp total power.
I've looked at all in one systems and I think it would be quite straight forward, but when I look at the Victron ecosystem, I'm not quite sure what I need.
I was guessing I need an off grid inverter like the "Multiplus II 5000VA" and a solar charge controller like the "SmartSolar MPPT RS 450|100"; is this fine or is there anything else or anything better that I should consider?
