Hey Shadowmaker,I am surprised of this here. Not the fact that your inverter is mounted low/outside/Alaska. That has to be a major waste of energy to melt that much snow and keep the grass green all year round. I mean I live 62 degree North here in Finland and we have -35C days in the winter, but my tall concrete foundation can get frost on it as early as -3C and it's not a crawling space, I have rooms there underground (three story building). Also my house is 70 years old so no modern building materials used, thought thoroughly renovated some 15 years ago.
Don't know how much you pay for gas heating (nobody uses gas heating here), but if it's not free, I'd expect notable savings with some insulation.
At first I was going to install my inverters outside, next to my panel array, but eventually decided against it because I wanted batteries. I have some 150m from my panels to my "solar corner" (=old horse stable, now fully insulated) and another 100m to my house, so expensive ground cables were needed.
While your heating setup seems to be well thought, you do understand how much energy has to be wasted to keep 2 feet worth green grass through winter in harsh climate like ours? I bet I could easily heat my old horse stable (300m2/3200sqft, but only +10C/50F) and my nicely insulated outdoor swimming pool (20m2/220sqft, +30C/86F throughout the year) through the winter months with that much energy.Hey Shadowmaker,
My home is pretty efficient in regards to heating. I have a 5 star energy rating and would say I pay less for heating per sqft than about 98% of the people in my city. I have a condensing boiler, tons of zones, all radiant and all digital controls plus a side arm for mixing with a super store hot water heater. Each floor has a manifold allowing for these multiple zones. All bedrooms have their own thermostat. Two attached double garages also have their own temperature control. My current home of 3800 sqft plus 4 car heated garage (garage are set to 50 degrees) is cheaper to heat than my previous home of just 1800 sqft no heated garage. My previous home was forced hot air, also gas. My boiler is rated a 97.5 efficient.
Here in Alaska we are mostly new to solar and probably not as advanced as some other states that may get more sun year round. That being said we take our heating seriously and have some pretty efficient systems. My home is well insulated, so much so I have whisper green fans in all bathrooms running 24/7 as the home is on the edge of being too tight. Plus the upward air movement helps radiate the heat. The downside to all this insulation, 24 inches of R 49 in my attic means the panels on my roof will likely be snow covered for a while. Like I said we are good at heating not so great at solar. My concrete slab does have styrofoam board insulation around it but the ground is still warmed by that radiant heat.
Think of the heated sidewalks you may see at some stores in the winter. Likely they are not heated to anywhere near my home's temperature yet the snow melts not just over the sidewalk but to a few feet around them. When the snow comes I will take a picture for you guys.
Sam
My panels don't get snow covered. Here they are in blizzard and at that same time they produced ~8kW (I have four inverters, so 2kWx4=8kW), which is ~20% of my nominal peak (44,1kW). No micros, just two hybrid Deye 12/15Ks (which are about identical to Sol-Ark 15K) and two grid tied Bluesun 15Ks.You appear to be in Finland. May I ask if your panels are covered with snow through the winter months? Also do you use micro inverters?
Certainly not a pro. Only just over half year experience on solar so far. I did go straight to the deep end with my unconventional setup and did 99% of all installations myself, but could not have finished without the help of good people here on the forum.Wow,
You are way ahead of me. That is impressive! Do you suffer much production loss in summer from the steep angle?
Your are a pro man. My install was by a professional though I may solar up my shed. POCO will not allow it to be grid tied though. Are you using super strut between posts?
Seriously you inspire me to do more.
Sam
I don't think I'm the right one to say much about micros. There are lots of people here who actually uses those, so they might have more accurate info for you. To my understanding they work really well if you have mandatory shadows from trees etc. every day, or snow over your panels in winter. Also individual panels can be monitored, so it should be easy to detect problems in their early stages. That's solar porn for the real enthusiast. I decided against micros because only shadows for my array are coming from clouds and I'm pretty sure snow isn't going to be a problem for me.Hey Shadowmaker,
I agree the snows reflection of light and colder temps increase production more than most people account for. My few but growing number of solar friends in Alaska stress that as a big benefit having snow reflect the light . My solar shed dreams will likely involve strut for mounting as I am facing solar south and do not worry too much about shading. Plus the strut is pretty easy to use and affordable.
Do you have any fellow solar enthusiast in Finland using micro inverters? This was a hot topic on my install. I paid an installer as I have limited knowledge on solar and do not like getting up in high roofs. The debate on micro inverters is big in Alaska. Most people use them. Those who have them seem to dislike them long term as they often fail more than predicted. They also seem to way under produce. My theory is the extreme cold climate shortens their life greatly. Any insight on the topic? I am going without them so my path is set for now. Hope I made the right choice. My solar shed remains a work in progress but is set up currently as a mico grid to power my EV. Will send pictures of it after work today.
Sam
One is a lie, and the other doesn't exist. lol
Sol-ark is better currently. Hopefully any lingering issues with the 18kPV can be fixed in future updates.Hi Guys, so whats the Conclusion between Solark and EG4 18k?
can both do Peak Shaving and UPS functions?
What issues have you come across with Peak shaving and the UPS functions of the Sol-Ark?Sol-ark is better currently. Hopefully any lingering issues with the 18kPV can be fixed in future updates.
I found this one day while looking around Schneider’s web siteThey use a Low Freq., Toroidal transformer. Proven in different applications to be robust as also used in another fine brand name of inverters. The Schneider brag about many still in use 15-20 years later but only offer a 5 yr warranty. You should do some research of your own first from people who had problems and tried to contact Schneider for warranty issues before you decide. That is why I my self decided to pass on this fine unit that will do more than it is rated.
Please expand upon this. What lingering issues with the 18Kpv?Sol-ark is better currently. Hopefully any lingering issues with the 18kPV can be fixed in future updates.
Delete.Sol-ark is better currently. Hopefully any lingering issues with the 18kPV can be fixed in future updates.
The Sol-Ark can accept up to 17K of solar, but only 15K is usable. The EG4 can accept up to 21K of solar, but only 18K is usable.Is the sol-ark actually limited to 15kW DC solar? I thought it was 18-19kW.
Where did you come up with these numbers? And what is your definition of “usable?”The Sol-Ark can accept up to 17K of solar, but only 15K is usable. The EG4 can accept up to 21K of solar, but only 18K is usable.
That would be hard to do, since one doesn’t exist. lolI look forward to your comparison of the Solark 15K and the EG4 18K on youtube when you do it, Mr Rocky Broad Solar LLC
Military discount?! Lol!! I asked. Hubs is 100% Vietnam vet disabled. They give no military discounts! Period!Military Discount at Signature Solar?
