How much wall space does a Victron system require?
S610
Deep South
Trying to estimate wall space required for a Victron system. Will have two MultiPlus-II inverters and a Lifepo Battery. I have the dimensions on a battery but don't know how much overall wall/floor space all of the equipment would take up. Planning to put it in a 10' x 15' pantry.
Each inverter's dimensions are 22.5" x 10.9" x 5.8". You'll need around 4" of clearance around the outside of each inverter.
For the units and clearance, ballpark 3' x 3' for just the inverters.
I received a reply from the Victron dealer and will include it here in case others have the same question and see this thread.
He said: "For your batteries and inverters you’re looking at needing about 4x7 feet." I assume that space will accomodate the other equipment required since that is what I asked.
