MrNatural22
?SW sunshine =⚡️⚡️lit up thru the darkness✌️
Looking for advise on which would be a better option for a cargo trailer conversion I’m slowly building.
the trailer is a 6’x10’ v nose so roof area is limited because of a roof vent in the center. The current plan was 3 100w panels in series—60v 5-6 amps into an MPPT for efficiency. They weigh approx. 65lbs together with an aluminum frame I built 65” x 47”.
I’ve found at santan solar a 327w 57v 5.7amp used mono high efficiency Sun power panel weighs 41 lbs. 61” x 41”.
Mounting one big panel is easier than mounting and securing the three together (VHB tape method w/safety tethers)
Is it better and more efficient to use the 3-100w or go with 1-327w with basically the same output ratings?
I had the three originally mounted on another bigger trailer build on the side and swinging up for use. That’s why the conjoined panel set up.
