PfloydBham
- Dec 27, 2019
- 54
I have a battery with 18650 cells that is 7s4p or 25.9 nominal volts. I have a 100 watt panel which is about 18-20 voc. I also have a 12/24v PWM SCC that has a lithium setting. The manual indicates that it will charge at 28.8 volts if I connect to the battery first then connect to the panel. Will the charger increase the voltage to match the battery? or, do I just need to use two panels in series to input 36 volts.
Pink
Pink
