My 2 cents. Subtract 5 cents.
I think you have a great system. I’d not have any buyer remorse. Once money is spent it is spent.
![Beaming face with smiling eyes :grin: 😁](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f601.png)
In most cases you would have given more money for some of the rosie then your whole victron - battery complete mobile system. Personally think victron makes great stuff. The victron shunt drifts over time for soc if not cycled often. The victron inverter derate at around ~77f degrees. Will Prowse showed that with the victron inverters but didn’t remember him stating it was factor of the ambient heat. Lot of electronics and such shift due to temp. Why ppl use to demand mil-spec. But they are still great. If you buy on eBay or amazon make sure test everything right away. As for the heat they all have operating ranges. What cracks me up some expensive units with ip ratings are suppose to be handled with kid gloves. Again Victron probably makes best of the best for the money. The Victron 3000/48 is a ul bargain. You just have to figure it out and you will for settings. I’d have no buyer regrets. You built a very capable upscale mobile unit for emergency situations. My own system is emergency due to unmaintained grid system - overloads. My electric bill is about $1400 a year with no solar as off set …so am not doing it to save money or be off grid.
I just bought a new split phase 120/240 inverter and spent almost a year’s worth of electric money just on it. However the cheap grid electricity is not any good if it is not reliable or gets taken out by storms all the time. Ppl are over loading grid with ev and more houses too. So an emergency setup is great idea unless you like messing with gas generators. The gas generator is about my last fall back. Watching the sun recharge batteries is comforting…but at same time bad weather means not much solar charge. In event of a serious hail storm or high winds might lose solar panels too. I keep extra panels stored away lighter the better.
I see nothing wrong with your outlet drop box. Lot of the common electric strips are not label with UL either nor even breakers but ppl still use them. Matter of fact I considered buying one of those boxes too. Job sites use to have them with just 4 outlets. Crazy thing construction workers ran straight out of gas generator basically no protection. Construction workers are easy to replace was old mentality.
![Flushed face :flushed: 😳](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f633.png)
Several youtube content makers have used that same drop box on their demo build systems like you have done.. i had seen them on Aliexpress. .
What I have found with these inverter systems they all have quirks in particular the software and functions. Generally the more basic the more reliable. I considered adding a Victron Phoenix 1200/48. Still considering it. Considered 12v too - hook car battery if really bad. Ppl in middle east use to do that all the time. Raise hood hook up inverter tvs. I’d sometimes watch them and their tv. The small victron are exceptionally cheap in price….but everything for victron inverters after that jump way up in price. Strange but those small inverters are not listed as derating until get around 40c or around ~104f. Down side to bigger transformers. The Victron 10k quatro loses a stated 2000w at temps of 77f and about to the next derated temp at 3500w for 104f. My inverter if operating temp hits 122f it will shut down. So remember the heat has impact add in operating temps. When checked my current mpp solar 3048 inverter yesterday it was reporting at stated temp of 107f while charging batteries….. so the big Victron would have been derated a lot. The victron will chug up to ~149f but a 10000w will be a 4500w inverter. That is great. The garage is hot in summer my listed 107f in operation was garage around 80f air . The previous mentioned little victron is only inverter would trust in my home. Might put it on bed room ceiling and just look at it. ….be like some others in victron club in love with blue.
I’d venture a good guess in summer time some ppl - equipment derates with other names too. Maybe shuts down completely and if firmware is faulty does not protect - things burn up - burn out. Heat kills electronics. Some expensive outdoor rated units … the makers do not want them in direct sun - heat. Or in some cases no rain on ip rated inverter…
The Rosie is nice but expensive. Find the temperature specs on the rosie. I’d question the “made in Merica” claim too. Some lawyerS foamed at mouth over those law suits in past Made In America got the claimer - lost revenues. Ask them questions about temp. Electronics is often spec’ed higher for percentage ratings ie resistors change with heat and so do batteries. Solar panels lose power due to heat too.
I’d have no regrets with Victron and your setup. Enjoy it and keep out of sun shine. Some ppl on here have their systems in climate control. Watch as temps warm up and more ppl have problems not realizing it might be over temps. The inverter firmware-software is suppose to report it.
Your stated location of Florida makes heat a concern. Have no regrets about your blue if it functions properly for you.
