Divad
Hi, I needed a battery in a hurry to replace my failing 12v 100ah FLA and bought this one as it was close and available. 12v 200ah battery
I now want to make a 200ah 24v system with an all in one, in the battery specs they say that it can be put in series with a max voltage of 30v,
"Maximum In-series voltage 30.4V"
Great but further down the page they say
"Can be connected in parallel & series for larger capacity (no higher than 24v is recommended, and a secondary 24v BMS is recommended for even charging and discharging/balancing of series connected batteries). "
Would the secondary 24v BMS be external or would I need to replace the original BMS's with 2x 24v one's
Thanx Dave
Thanx Dave
