Mikeyfromoz
- Aug 1, 2022
- 10
Hi,
Can I put 1 x 16s 48V 100Ah with 100A Daly BMS in parallel with 1 x 16s 48V 130Ah with it's own BMS (each string of 16 batteries has it's own BMS)?
I will be pulling a max of 95A in total with the inverter, so in my mind, it wouldn't matter if one BMS turned off before the other, because each individual BMS can handle the load all by itself (each BMS will be set to 100A max discharge... charging will be a lot less than that while both BMSs are on as they will be connected to 5Kw of solar panels, but they will also be set to 100A charging each) .
As for charging and discharging, in my mind, the voltages will always be the same (give or take milliamps) between both strings, so there will just be more amps going in and out of the 130Ah string than the 100Ah string as the voltages rise and fall...
I will have the inverter positive connected to one bank, and the inverter negative connected to the other bank, with short jumper cables between both banks (or BMSs).
So, will that work???
Cheers,
Mikey.
Cheers,
Mikey.
