As introduced in this thread: https://diysolarforum.com/threads/question-about-solar-panel-install-on-whole-roof-of-an-rv.33507/
Here are some pictures describing the 1700W Solar DIY installation that I've just completed on our Winnebago Navion.
The structure holding the panels is built from Aluminum Strut rails (from Grainger) and Aluminum Strut Angle brackets (from McMaster Carr). The Strut rails are held to the rooftop with VHV tape (3M RP62) and then covered with Lap Sealant (Sikaflex 715). The height of the structure is 8.25-in, with the front panel tilted upwards to 11-in. I tried keeping the structure as low as possible while providing reasonable clearance for the Mabru 12V A/C unit that's installed up-front. Also, as shown, I did have to account for the Roof-Access Ladder on the rear passenger's side, and the Skylight on the rear driver's side,
The 4 LG Solar panels (425W each) are bolted to the Strut rails that run from side to side (not shown in the first few pictures), and on the top, they are also held in place by End-Clamps which are bolted to the Strut rails that run from front to back.
--EDIT--
The bottom Strut rails are angled at 3-Degrees to account for the curvature of the roof... This was done by cutting the bottom of the Vertical vertical support pieces at 3-Degrees on a Miter Saw.
--EDIT--
