Hi All
I have purchased two SPF 5000 ES (5KW) inverters from Growatt and two 48V 100AH LiFePO4 batteries from GSO. Using a busbar, I am planning to connect each battery and inverter as follows.
I am assuming that at any time, each battery to the busbar current will not exceed 100A (since the battery is 100AH), and input drawn by each inverter from the total 200AH battery bank capacity will not exceed 100A. So, I am thinking using 2 AWG wires for ALL of the below wiring, and the use of the 150A/60VDC MCB before the inverter is good enough. Is my understanding correct?
Thanks
asankha
Thanks
asankha
