Henry's Cat
Should I buy extra solar panels, and have 24 volts coming from solar panels, whilst still only having a 12 volt battery?
I don’t think you quite understand what voltage is required for your system to work, your 24 volt system with 200 watts wouldn’t charge a 24 volt battery you need to be 5+ volts higher than your battery full charge voltageI'm so sorry, this is cool, Ty for your reply.
I have an epever 40 Amp charge controller.
I do appreciate your reply, but feel the points somewhat moot.
So, ideal world, I have solar, giving out 24 Volts/ 200 Watts. This is fed into Charge controller (I use 40Amp Epever),
I would then want a 24 Volt battery, but batteries are expensive and I wish to carry on using my 12 Volt battery with my system.
I'm not being rude, but it is more a hypothetical question, rather than a practical here and now question (though it likely will happen at some point).
This is the simple answer that's useful to beginners. I've got a 40 amp renogy rover. I'm still a bit unclear how many watts I can input at 12 volts and 24 volts.Two 12v panels in series for 24v 1 MPPT charge controller 1 12v battery
Connect battery to charge controller first so controller knows battery voltage.
Then connect your two 12v panels in series (24v) to the charge controller.
Your 12v battery will be charged at correct voltage.
Does this help?
The manual says 520 watts for a 12v system and 1040w for 24v system.This is the simple answer that's useful to beginners. I've got a 40 amp renogy rover. I'm still a bit unclear how many watts I can input at 12 volts and 24 volts.
